We connected a Laptop via svga and trid to turn on the TV. TV did not come on. So, we disconnected the svga cable and tried to turn on the TV. no luck. We checked the power outlet and power is there. Any ideas?
-   I have the same problem. The yellow power light is on but when you try to turn it on, the green light does not come on nor does anything happen. It's like a dead tv. Any suggestions to fix this problem? Is it not fixable? Should I junk it?-   funeral1234
Jan 30, 2009
-   tv will not power up starts then it dies with light on bottom
-   griffinhawai
Dec 23, 2008
-   the on and off button just clicks and will not come on.-   Guest
Nov 03, 2008
-   i have the same poblem for my 50inch flat tv..lost power i tried everything..what is going with the Flat screen TV. -   Guest
Apr 23, 2008
-   Vizio flicked on and off rapidly and than would not turn back on. There is a yellow light for power but no response to the button on the TV or the Remote.-   Viziosucks
I have a blue line running from the bottom of the 32" vizio to the middle of the screen on the...
(More)
I have a blue line running from the bottom of the 32" vizio to the middle of the screen on the mid right side of the tv. Tried to reset with buttons on the side of the set, and it did not work. would appreciate any answers if there are any. Thank you, Bob. Have photos of line if that would help?
On my Vizio 32" the picture is in blue and yellow. All the red is gone. I have reset the RGB...
(More)
On my Vizio 32" the picture is in blue and yellow. All the red is gone. I have reset the RGB but it does not fix this problem.
yellow light comes on when i plug it in and it wont turn on like it doesnt have power but the outlet works
Comment by Guest, posted on Apr 07, 2008
I have been having the same problem. My TV turned off randomly one day and ever since it has been acting vey weird. I would unplug the cable in the back for a couple of minutes and sometimes the amber light would come back. But now there is no amber light and the TV will not turn on at all.
Comment by Guest, posted on Mar 21, 2008
I am having the exact same problem. I turned it off on day and now it will not come back on. The amber light is on but no luck with power. I've tried the buttons on the unit and the remote.
I have an amber power light, but the TV will not power on. It started turning off in the middle of a program, then come back on by itself. Now It will no turn on.
i have also had this problem when i connected my laptop to my tv.
it worked fine for while until i turned it off and then back on again.
the tv would not turn on even after unpluging it and pluging it back.
