Question about Electrolux EW30GF65GS Gas Range
How do you display fault codes?
My electrolux oven stopped working after I used the oven clean feature.
  • Official Brand Answer
  • 4,342 Answers
Hello Michael Anderson - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Does it display an error code? If it does not then the range may possibly have faulty wiring or EOC. I suggest contact a professional to move forward accurately for a proper diagnoses.
Posted on Jan 08, 2013
3 Suggested Answers
ndguy2481
  • 251 Answers
SOURCE: How to clean lower oven of 30" electric range by electrolux
try a lemon heated and the acid will eat away the food
Posted on Dec 01, 2008
  • 731 Answers
SOURCE: Hi! We have an Electrolux E36DF76EPS. I ran the
I'd check the thermostat for continuity first
Item 119 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Range-Parts/Model-E36DF76EPS/1412/0122007/R0705157/00003?blt=06&prst=0&shdMod=E36DF76EPS
Posted on Feb 08, 2011
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Tip
Electrolux Model EI30GF55GSE Self Cleaning Doesn't Work
When using the self cleaning feature, you may see the panel flash remove shelves then go off after a minute. The solution is that there is a bar in the back left of the oven that is connected to the self cleaning sensor. After sitting a few months it may get stuck. Try moving or flipping the bar back and forth a few times. you should hear the sensor clicking . Then try to clean the oven. It worked for me.
on Oct 16, 2011 | Electrolux 30" Self-Cleaning Freestanding...
Frigidaire oven fpcf3091lf eo90 code keeps lighting up and beeping after the power went out.how do I get it to stop I have unplugged it and waited 5 min. But will come back.
http://manuals.frigidaire.com/prodinfo_pdf/Specsheets/FPCF3091L_1011_EN.pdf
Electronic control has detected a fault or error condition. Press CANCEL to clear the display & stop beeping. Try the selected feature again. If the E or F error code repeats, remove power from appliance, wait 5 minutes and then repower appliance. Try the selected feature again. If the fault recurs, record the fault or error code and call for service.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902218en.pdf
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316904423.pdf
May 30, 2015 | Frigidaire Ovens
The 'remove oven racks' light won't allow me to start the cleaning feature on my electolux oven
Thank you for your post, friend!
I see you are having challenges with your Electrolux range displaying "Remove the racks" when they have already been removed. It sounds like you could have a possible issue with the sensor or control panel within your Electrolux range. I would recommend performing a reset on your range. You can do this by disconnecting power from it for ten minutes. If this does not help correct the issue I would recommend reaching out to a professional and scheduling a service appointment for a proper diagnosis. This would help avoid any unnecessary part purchases. -Matt
Oct 21, 2014 | Electrolux Kitchen Ranges
How to fix error code 15 on Electrolux electric range.
It is likely you may have used self-clean feature at some stage before this happened. The error is something to do with oven overheating. This is common when you use self-clean. The solution may be to reset the thermal fuse.
See this thread on internet for possible solution. Hope it helps.
F15 Code on Electrolux EW30DS65GS5 The Kitchen Appliance Repair Forum
Sep 28, 2014 | Electrolux Cooktops
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
Jul 13, 2009 | Electrolux Kitchen Ranges
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux EW30GF65GS Gas Range Logo
158 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
