Question about Innovage Touch-panel Phone 1502084
My shift 3 Talking Caller ID Phone will not ring when I call it.
I can't figure out how to set the ring tone.
  • midyette1 Jan 23, 2009
    Just bought the phone today (1-22-09). I set the other features, but w/ringtone instructions say Press Flash button and choose the music or ring you want. Nothing is written about how to select/save your choice. I can scroll through the tone options, but don't know what to do to store it.
    I have no incoming ring, just caller ID announcement. What will work?
Once you select the one you want it will automatically store. You can press the handsfree button to return your screen to the home screen.
Posted on Apr 08, 2009
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
My ring tones have stopped working on my Blackbery
There may be a setting that got adjusted somehow. Go into your Options (the wrench icon) and select "Sounds and Ringtones." Under "Ring Tone," there is a volume setting -- make sure it is not set to "Silent." Underneath that, there is a setting called "Play sound" -- make sure that's set to "Always"or "Out of holster."
Do other sounds work on your BlackBerry (such as music files, video clips, or alerts)?
Jun 01, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I can't figure out how to set a ringtone to my text messaging contact...can u help
To change the ring tone, press Home > Menu, then tap Settings. Tap Sound & display > Phone ringtone. Tap the ring tone you want to use, then tap OK. The ring tone briefly plays when selected.
Also, take a look at these Droid Eris tones: http://www.exectones.com/
May 21, 2010 | HTC Droid Eris by
I just got a verizon b.b. 8703e and I can't figure out how to turn on the ring tone
A ring tone can be set for specific contacts on a BlackBerry smartphone that has 32MB or more of flash memory.
To set a ring tone, follow the steps below:
1) Click the Address Book icon on the Home screen
2) Select the contact that a custom ring tone is being added for.
3) Press the Menu key and click Edit.
4) Press the Menu key again and click Add Custom Phone Tune.
5) Select the ring tone from the list of available ring tones.
6) Press the Menu key and click Save.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
Problem with vibration
You may have the volume turned down or on mute. Also if you personalized settings per contact those settings will over ride the other settings.
Also, if you programed your phone for a specific mode those settings will over ride the other settings.
From the phone settings menu go to your ring tone settings to test the volume of your ring tones. Also, in the settings menu, explore the settings for the phone in the Personalize option
Dec 16, 2008 | Motorola Cell Phones
I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Aug 28, 2008 | Office Equipment & Supplies
Initial settings on new cell phone
you can not change that the only thing you can change with the ring tone is volume sound and vibrate nothing else
Sep 03, 2007 | Samsung SGH-x427m
Innovage Touch-panel Phone 1502084 Logo
247 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
