Question about IBM ThinkPad T21 Notebook
Laptop will not rebot from HD
Hi all. I reloaded winxp home from my cd having set the bios to boot from cd.Reinstallation was fine.Reset the bios to boot from HD but it does not reconize this as each time I try to reboot, it comes up with the cd screen and ask me to free F1.When I put in the xp cd it starts to reload xp or it open windows normally.How can I get it to open from HD at start up.The laptop is IBMThinkpad 600e.Yes it old.Ionly use it as a back up for my PC.
Many thanks,JAH
  • 2 more comments
  • jameshempton Jan 19, 2009
    Have now changed the boot order and all ia well.Many thanks for all your help .Regards JAH.UK
  • Dan rogers
    Dan rogers May 11, 2010
    Here ya go check out this pic. @ bozape This is for both of you. I would hate for you to recommend this boot order to someone else
  • Dan rogers
    or when you instslled windows and formatted the hard drive/created a partition did you set the partition to boot?
  • Dan rogers
    sounds like when you changed the boot order back you may not have saved your settings in bios. The boot order should resemble something like this
    1. CD-Rom
    2. USB-Floppy (something)
    3. HDD
    Master:
  • 413 Answers
Sorry but did you say all is working fine now? Was this the problem with the boot order?
Posted on Jan 19, 2009
  • 44 Answers
Check the boot order in the Bios
Must be:
HDD-0
CDROM
etc
My Laptop is Satellite L505-S5990,After i change boot sequence from booting with CD rom to HD it won't effect changes.WHy is it this way>Any tips as to why it is so and how i can change boot...
Changing boot sequence.
Go to bios setting, click "F2" upon start up( when you read the bios and HD readout ). Choose the part boot sequence, click " enter" and choose what drive will be use first.
Save the settings upon exit.
Hope FixYa helped you out!
Aug 17, 2011 | Toshiba Satellite Laptop with Intel Core 2...
My laptop won't start and says "NLTDR is missing" press control alt delete to restart... why is that?
Windows is corrupt...
Sol = Reload Windows XP
you will need an original WinXP disk....insert the disk in the CD drive and restart...let it boot from the CD (to make changes to boot sequence make changes in BIOS)
once it boots from CD then repair you OS or install a fresh copy of the OS
May 29, 2011 | Computers & Internet
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
I have a acer 5100 aspire that won't recognize the hardrive half the time and won't find some of it's usb ports. I have reloaded windows and even tried different hard drives (used not new) and it seems to...
Do the following:
  1. Check in the BIOS to make sure that the HD is present in the system before proceeding..
  2. If not then power off the laptop and then carefully remove and replace the HD from and to its connector.
  3. Then secure it then reboot the laptop.
  4. Check the BIOS settings again to see if the HD is recognised.
  5. If you still can’t see the HD then obtain a USB to IDE / SATA adaptor cable from eBay or your local PC store and remove the HD from the laptop and lay it down on a flat horizontal surface and use the adapter to connect to the laptop’s HD and connect the USB to another PC. This will show if there are any issues with the HD itself and will allow you to format it if necessary.
  6. Then replace it back in the laptop and all should be well.
  7. If not then you can suspect that you have an HD controller issue which is a very costly repair in a laptop.
  1. If the laptop will boot or you have a bootable CD / DVD then change the boot sequence in BIOS to be CD/DVD then Hard Disk.
  2. Reboot the laptop.
  3. Once booted look at the Device Manager to see if there are any errors showing in the Storage Devices and the Hard Disk in particular.
  4. Then go to option 5 or use the bootable CD / DVD to reformat and rebuild the hard drive.
  5. If all the above fails then install a new Hard Drive, format it as required and reinstall the Operating System and applications.
Oct 23, 2009 | Acer Aspire 5100 Notebook
Installed new harddrive, installed winxp pro all is fine, except i cannot change the boot sequence, it goes from cd to the 4th which is hard drive, and when changing them around they all jump 2 at a time,...
You need to set your Bios setting to read which ever port you want it to read first. You can usually enter your Bios settings by pushing your F2 key when you first start up. (you might want to look at your specific manual first) Once you enter your BIOS, then you can set which port (device) you want first. If you are no longer needing your disk drive to start first (usually set for first installs on new HD) then set your HD on the top of the list. Good Luck.22
Sep 06, 2009 | HP Computers & Internet
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
I am have a bit of problem puting winxp on my laptop because i have not got a fopply dr
   You should be able to boot the computer from the WinXp CD.  Go into the Bios and set the boot order to have the laptop boot the CD Device first. Then the other devices.  When it does boot from the CD it will say (hit any key to boot from the CD.) It should start the Windows Setup.
Sep 22, 2008 | Computers & Internet
Toshiba locked with a password
Download the UBCD (ultimate boot CD) burn it to a CD and boot your laptop up with it (you may have to change the boot order to CD)
There is a utility on the UBCD for changing the BIOS password.
http://www.ultimatebootcd.com/
Aug 08, 2008 | Computers & Internet
M2000 compaq
I am assuming you mean you are updating the bios? If so set the laptop bios to boot to the CD drive and try that. Then after its done, boot the pc with the CD in the drive. When you are done, be sure you set the PC back to boot to the HD.
Apr 25, 2008 | Compaq Presario M2000 Notebook
IBM ThinkPad T21 Notebook Logo
116 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
