Question about HP Deskjet 3510 e-All-in-One Printer
How do I remove the cartridges? They won't come out.
Is there a release button? The manual is useless.
    Problem Solver:
  • 7 Answers
Scroll down on this page to the link with the Users Guide, dl and open. It's HP so it's safe. It's on page 28 I believe. You need to press the top tab.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=18972&prodSeriesId=5157460&docIndexId=64179#2
Posted on Jan 03, 2013
2 Suggested Answers
2011 legacy trunk won't open with inside button release
Button probably bad.
Remove button from dash connect multimeter and set to continuity and press button listening for beep
Jul 15, 2012 | Subaru Cars & Trucks
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
May 25, 2012 | 1993 Jeep Grand Cherokee
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
It says the waste ink absorber is allmost full i cant find my manual how do I fix it
Right at the bottom of the printer case, underneath the cartridge dock, there's a tank holding a whole bunch of wadding/pads packed which soak up excess ink.
These pads need to be taken out, cleaned, dried and replaced. Then you need to reset your printer.
I've just done this on a Pixma ip2000. Basically, all the casing unclips one way or another, all needs to come off, but you don't need to remove the cartridges.
When I say it all unclips, it does save for the main casing which clips and there's screws at the front to remove.
Once dismantled, check out the area behind and below the cartridge docking area, you should see the wadding. Rubber gloves time.
Remove all the wadding, mine came in 6 pieces from an "L" shaped tank, remember where each piece goes because they're different shapes. Wash clean and dry the wadding, then replace them.
I couldn't get one piece back in, just too awkward, so I left it out. Made no difference.
Then re-assemble your printer.
Then you need to reset your printer to remove the error message. (This works for many Canon printers, yours should be the same)
1) Re-connect your printer back to the power source.
2) Press and hold the Resume button.
3) Press and hold the Power button.
4) Release the Resume button.
5) Press and release the Resume button 2 times.
6) Release the Power button and wait for the green light to stop blinking.
7) Wait for initialization to complete.
8) Press resume. (Once for power down, twice for test, 3 for eprom info, 4 for inktank reset).
9) Press Power button to accept the reset.
You can just go through the reset procedure, but you'll be pumping more ink into an already full overflow tank.
Sep 25, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
Stanley-bostitch B8E E66760 jammed and can not un jam it
i pushed down on the on the cartridge itself and then on the release button. it freed the cartridge and i was able to access the staples themselves. (the tray was full of new staples).
i replaced the cartridge empty, activated the stapler a few times...reopened the tray, reloaded it with the same staples i had removed, and it worked fine.
i found this useless information at the bostitch website:
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-7781364541754123555/view_question!PAGETYPE?sq=b8e&sc=1&sf=101113&st=526105&documentid=56717&action=view
Aug 05, 2008 | Office Equipment & Supplies
HP Deskjet 3510 e-All-in-One Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
