Question about Nordic Track Mc2100 Lts30 Treadmill Motor Controller
MY MC-1200 RUNS AT FULL SPEED NO MATTER WHAT BUTTON I PUSH.
Doesn't matter which speed button I select the motor takes off and stays at full speed.
  • 103 Answers
SOURCE: belt goes full speed when started the shuts off thats it
Hello there. This is usually a problem with the control pwb. The controller is what tells the motor how fast to run.
This item is available @ iconservice.com.
Locate your model number before going to the site. This is located on the lower frame (under the walk belt) or on your users manual. Once you have that you may go to the replacement parts section of the site and look for the controller.
Repair Procedure,
To locate this item you will need to access the motor area. Usually 3 or 4 screws on the rear of the unit on the opposite side of the walk belt. If the cover does not come off after those screws are removed then u will need to access under the bottom of the cover area to remove 2 more screws. This is done by tilting the machine on its side.
After removing the cover you will see the control pwb. (silverish with a circuit board) There will be a number of connectors on the controller. I suggest either taking a digital picture or writing down the wiring going to the board as to not mis-wire something when re-installing the controller. Remove the wires and there will be 2 screws holding the controller in place, remove them as well. After reinstalling the controller in the reverse procedure as above be sure to calibrate the unit. (directions should be located in the box)
Good Luck! Tim
Posted on Jan 05, 2010
Testimonial: "im believe it is called a motor control board and thats what i believe it is too. the motor is good but i am having trouble finding the right part "
  • 218 Answers
SOURCE: The Nordic Track machine's controls seem to be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Posted on Aug 11, 2010
  • 13 Answers
SOURCE: Nordic Track c2200 no speed
It likely is the controller if it was speeding up and down erratically. Check the position of the reed switch to make sure it is positioned about 1/8" away from the magnet in the side of the front roller pulley. Run a diagnostic program as follows. Press the stop and speed arrow up buttons until you insert the key. Press the stop once or twice until you get to a screen with 2 sets of zeros. Now press and hold the speed arrow up button until one number set shows 8.5. The unit will go to full speed so be careful not to be on the walking belt. The other number set should top out shortly at either 10.0 or 12.0 based on whether your speed buttons go up to 10 or 12. If the motor races past your top number,( don't let it run that way as you may damage the motor), pull the key. If the readout is above or below your target by more than .4 and not flucuating a lot, you may need to tune the potentiometer on the controller. Counter clockwise turn with a phillips screwdriver turns the motor speed down. Be carefull not to short out the controller board by touching components with screwdriver. If not comfortable ask a friend with electronics background. If you turn the pot. too far it will break. It will not go a full revolution in either direction and tiny movements are recommended. Again I believe your controller needs replacing.
Posted on Oct 03, 2010
vetteman3002
  • 2299 Answers
SOURCE: NTL07707 Nordic Track C2155 The treadmill ran at
I would say yes, you do need the controller. If you tried to run the diagnostics and it locked up then yes some component in the controller is malfunctioning.
Posted on Nov 01, 2010
ercupa190
  • 12223 Answers
SOURCE: NordicTrack speeding up for no reason
This make all this adjustments:
Make sure the sensor speed is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
Good luck, sincerely.
E.CUADRA
Posted on Nov 29, 2011
Blower motor
may be motor on way out ,,,,, the resistor for the system usually allows full blower power when set to top speed,,,,
Nov 22, 2013 | 2005 Ford Focus
The fan inside my renault megane scenic will not switch off
The fan speed relay has fused contacts keeping it in the high speed mode. It needs to be replaced.
Jul 28, 2017 | Renault Megane Cars & Trucks
My Jeep Shakes Front to Back while driving. Doesn't really matter what speed I'm going.
If your car do not only shake at high speed, it may be not the matter of speed. tires, may be the real problem. I just guess.
From Chinasinoy.
Sep 10, 2012 | Jeep Cherokee Cars & Trucks
Why do my john deere445 moves at half its speed even when petal push all the way down
is the belt slipping?is the linkage points loose and the pedal doesn't have full travel the rod should have some adjustment to take up the slack
Aug 17, 2012 | John Deere Garden
Motor lacks drive at full throttle
It could be that your prop has the wrong pitch, some props are made for high speed and it takes a bit to get out of the hole if at all, but others are made for power, or a fuel issue you should check your fuel filter on it and make sure your connection to the tank is not sucking air. also you may have a bad piston or one cylinder has no spark... so just check your fuel lines and filter if that doesn't fix it then check spark and compression, if all else fails get a prop with a lower pitch... hope this helps
Jan 15, 2012 | Boating
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Breaking in crf 450 engine
you pretty much can't hurt this engine no matter what you do but most important for all MX bikes is varied engine RPM speed so don't stay full power for long stretches and don't stay putting around for long periods vary your engine speed and gear selection as much as possible for first couple of tanks of fuel.
Ps - once you have done couple of tanks of fuel dump the oil and refill new - everyone forgets to do this! the more often you dump and replace oil the longer your bike will last without need for repair (FACT)
good luck regards Jamie
Jun 18, 2011 | 2004 Honda CRF 450 R
Why abs and advance trac warning light stay lited on 2004 ford expedition ?
Because you have an ABS System Malfunction
A repair shop will check for codes,diagnose &
repair it for you
Doesn't matter what check lights you get on your dash
You should be familiar with them all & the routine,
they have been there for 30 years now
Possibly a bad Wheel Speed Sensor
Jun 07, 2011 | 2004 Ford Expedition
Nordic Track c2200 no speed signal. My NT c2200 treadmill behaved erratically briefly (sudden speed changes up and down) before quitting altogether. The console now behaves as though it's working but the...
Oct 01, 2010 | Nordic Track Exercise & Fitness
Nordic Track Mc2100 Lts30 Treadmill Motor Controller Logo
35 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
