Question about Acer Aspire One PC Notebook
Trying to connect Acer Aspire 5920 to Samsung tv through a VGA to HDMI cable but not joy... have tried HDMI1 and HDMI2 slot on tv, and used Fn + F5 on laptop to select display but no option for TV :( PLEASE HELP!
  • 564 Answers
VGA uses analogue signals and HDMI uses digital. you'll need a converter box to make it work. Have a look on you tube.
Posted on Jan 04, 2013
  • 9 Answers
SOURCE: problems connecting my acer laptop with tv
Sound and picture are two seperate things unless you use an HDMI cable so lets just deal with the picture first
After you do the connection, you need to tell your laptop to present the picture to the TV.
1- On your keyboard, one of your function keys (F1, F2 etc.) will have a short cut for this as a secondary functionality. Check for the function key that has an icon on it that looks like a screen (usually it is f4 or f7). Then hit the key that activates  your secondary functions and the key you just identified. This should activate the VGA output and in most cases will also give you a configruation screen (where you can select it as a secondary display, dual display etc.)
If this short cut doesnt work, you can try this
2- Make sure VGA cable is connected on both ends. Right click your desktop on the computer and select "Properties". On the new dialog, select the last tab "Settings". Click the drop down box under "Display" and you should see the TV as the secon option, select it. Then select the check box that says "Extend my display...", click Apply and OK. This should expand your screen to the TV, you should now be able to drag windows from your laptop's screen to your TV's.
Good luck! (Instructions on option 2 are for XP, if you use Vista let me know and I will look up the terminology for that)
Posted on Oct 31, 2008
SOURCE: CONNECTING ACER TO THE TV
Hi I have an Acer Aspire 4920. It's a good laptop and have been using it for about 2 weeks now. One issue I have is that the VGA connector on the laptop has no screw holes which means when your try to screw the VGA plug to the socket via the thumb screws..you can't!! This isn't a big problem but its sub standard.
As far as connecting it to the TV is concerned. The laptop should have a yellows S VIDEO out din socket on the left hand side near the buillt in NETWORK and MODEM Line ports. You need to connect a SVIDEO cable from here to the TV's SVIDEO or SCART(using a suitable SVideo to Scart). Then make sure the TV is set on the correct SVIDEO input. Now reboot the laptop. The [FN] + [F5] only works if you are using the VGA output to a LCD or Monitor/Projector. Once back into windows desktop you need to go into the properties of the graphics card and activate it through the menu under one of the tabs.
Hope this helps.
dab
Posted on Sep 18, 2008
  • 74 Answers
SOURCE: Fn F5 not working
Check the BIOS - some laptops can be set in there to start with the LCD, monitor or both.
Hope this helps
Posted on Apr 30, 2009
tvservice306
  • 458 Answers
SOURCE: i am trying to connect my acer aspire 5100 laptop
try adjust computer viedo for 800x600 60 HZ output
use keyboard Fn key + F6 (use manual ) copy to tv.....
Posted on Nov 19, 2009
buzzpuppy
  • 36 Answers
SOURCE: How do I conect my Acer aspire 5750 lap top to my
"Out of range" means that the picture displayed by the laptop cannot be displayed by the TV, either because the resolution is not supported or the refresh rate is not supported.
Sometimes, I've had to set the refresh rate (from the laptop Display settings) to 59Hz to get it to work as opposed to the default 60Hz.
What resolution does your TV support? What resolution does the laptop support?
Matching these as closely as possible and you'll get the picture on the TV screen.
Good Luck and let us know how it goes,
-BuzzPuppy
Posted on May 01, 2011
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
Hi, I am trying to connect my Acer Aspire 5600 laptop to my Sony Bravia (HDMI) TV. I bought a VGA cable to connect the two (because my laptop is not HDMI). Once i have plugged in the VGA cable in both...
The Bravia needs the video input to be changed to PC when you connect a computer to the Bravia.
You still need to press FN + F5 to divert the laptop video data to the video port on the laptop for the TV.
May 22, 2011 | Computers & Internet
How to connect/configure my acer aspire 4736Z to my LCD TV using the HDMI port/cable of my laptop? i tried to connect the HDMI cable but my laptop hangs...please help
for HDMI, I guess you just connect it with HDMI cable to your LCD TV, and use the FN+F5 or F6 to switch display from laptop's LCD to external. I think it should be the same way as using projector.
Sep 30, 2010 | Acer Computers & Internet
Acer aspire 3003LCi will not project on tv we are using vga cable and have tried the Fn and F5 buton
Try holding the fn & F5 buttons down for a good few seconds. Try fn and F7 too.
Right-click on the desktop and choose properties, and see if the 2nd monitor is recognised or not.
It might be a duff VGA cable, or crappy MS drivers instead of the real thing. Always worth downloading some fresh ones.
Jul 23, 2010 | Acer Aspire 3003LCi Notebook
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
I am trying to connect my acer aspire 5100 laptop to my HD tv i have olso a vga cable when i connect it and go to tv menu and connect computer the tv screen show there are no signal can some one help me...
Make sure you have used the FN + F5 button to switch your laptop to external display.
Also is you are using VGA to component lead be aware that many of these dont work
Nov 19, 2009 | Acer Aspire 5100 Notebook
Connecting aspire 5610 to dlp 60" screen
Try plugging the HDMI cable to the TV and your Computer while the computer is off. Once it is connected, turn the computer on and it should recognize the cable.
Sep 21, 2009 | Acer Aspire 5610-4648 Notebook
Connection vga to tv
on the left side i think !! u have a yellow connector named Svideo !! if u have the cable corresponding this connector, connect it to ur TV via the Video input and press ( fn + F5 ) on ur laptop.
if u need audio !! connect the audio output of ur laptop to the audio input of ur tv with an audio double layer cable.
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
How do i connect my acer 5738 laptop to my tv
First of all your TV should support both HDMI and VGA.
If it does lets start with HDMI as you will get audio through the HDMI cable.
Connect the HDMI cable to the TV and set the source on the TV to HDMI using your remote control, connect the other end to the laptop, hold down Fn and hit F5 to toggle between screens.
See if that helps and let me know how you get on.
Good luck
Aug 21, 2009 | Acer Aspire 5720-6661 Notebook PC
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Acer Aspire One  PC Notebook Logo
240 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
