Question about Mitsubishi Heating & Cooling
Mitsubishi mr slim light blinking
Unit starts to come on, but then stops and one light just keeps blinking
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
  • 8 Answers
SOURCE: Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Posted on Jun 10, 2009
manhandy
  • 146 Answers
SOURCE: Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Posted on Jul 18, 2009
SOURCE: Mitsubishi Mr slim Airconditioner error check P8
I Have same problem
Posted on Sep 28, 2009
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
Blinking operation light
It may have had a power surge, turn of the power to the air conditioner & leave of for 3 hrs, it may reset it & start working again. give it a try.
Sep 05, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
MSH12TN Left green light keeps blinking and the air conditioner keeps going off. Room temp is over set temp.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Outside unit do not run.Red light blink 6
That is a trouble code signalling that your unit needs service. It is time to call a professional for help!
Jul 13, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Right Indicator light blinks; left is solid; nothing in manual about this pattern
that is an error code.
count how many blinks after a pause and that would be the error code.
could be 4 , 5, 7, or 9.
you could reset it by un plugging or removing power for ten minutes and try it again.
if the problem would re-occur, then there is something wrong with the unit.
as it runs, observe everything and keep me posted. see if the fn outside is running, if the filter is clean, or if the compressor is running, etc.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Blinking light
the light blinking is an error code. you can count the number of blinks from a brief pause. it would continue to blink the same number of blinks after a brief pause. count this blinks and you can help the incompetent person that installed your unit to diagnosed the unit from the error codes that you will give him.
if you unplug the unit, it will reset and run again. after a few minutes, the sensor would sense the trouble and turn off the unit and display this code again as a blinking light.
tnx for using fixya.
drcool
Aug 27, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Problem with mitsubishi slim
I am not familiar with a P8 code nor do I understand where you are seeing this But, go to mrslim.com and look under Customer resources, Library and then input your model number. Select Technical & Services. Product Catagory is Mr. Slim Ductless, Sub Catagory is M-series Multi Split, Current models. Remember you have inside units and one outside unit. You will need to look at each model number to find information on both. Usually Mitsubishi's will have two lights that will blink in patterns to indicate what could be wrong. The P8 code is new for this Diamond Dealer!
Sep 30, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
356 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
