Video and sound problem with 47LF65 LG LCD TV
Hi, I got an LG 47LF65 about 5 years old but for the last few weeks the TV starts to playing around, Everyday when I turn it on the TV starts ok but after few minutes starts to appear lots of line the screen starts to flicking but after 10 - 20 if you turn it off and on few times the TV starts to work again but the problems are getting worse everyday, like today the sound stop working, I checked the volume, the mute button, the audio settings of the TV and everything seems to be ok but no TV sound, PLEASE HELP?
SOURCE: stripes on screen
This is just a poorly designed TV, it has thermal problems, if you notice there is room for a fan at the top, but they left it out. I have had the power supply die and I fixed it, no help from Niko. I have resolved to let this tv die when it is ready now and move on. An expensive lesson on early adoption of cheap off-brand products.
Posted on Apr 14, 2008
welcomejee
  • 10594 Answers
SOURCE: Goodmans LD3755HD Picture Problems
Let me give you Technical tip. Find "IF Block" in TV, it would be near Tuner, Open the IF Block and resold it with solder iron. make sure not to make bridges between solder points. Reason of problem in your TV is .."acostic tuning frequency drift". I dont know, how to clear my point. But I am sure, this will solve your TV's problem. Good luck.
Posted on Jul 30, 2008
  • 191 Answers
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Posted on Oct 11, 2008
  • 6 Answers
SOURCE: AWA LCD TV - Blank screen (with sound) - picture appears for a few minutes
Rplace both capacitors on inverter board along with surface mount fuse on other side of board. The caps will aapear puffy on top.
Posted on Jan 04, 2010
budmrtn
  • 11361 Answers
SOURCE: I'm having problems with my 42 inch LG LCD . when
That can be the T-CON board failure or main board. It can be heat relate so you will need freeze spray for electronics troubleshooting to cool down the T-CON board first to see if it starts working again.
You should also check the power supply first to make sure it does not have any bad caps and the DC output voltages are OK.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 18, 2011
My lg tv has sound but no picture
Sounds like power supply is failing
Dec 24, 2017 | LG 42LC2D 42 in. LCD HDTV
Hi, i have a LG LCD 42" TV. When i turn my TV on it is a black screen, i can hear the channel but have no picture, do you know what might be causing this? its only 2 1/2 years old. it only does it...
Sounds like the back-light in your TV is going bad, Happened to me on my 42" vizio, same symptoms I would suggest giving lg a call, they are usually quite eager to help and will repair it for very cheap or sometimes free depending on who you talk to.
May 02, 2011 | LG Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
I have an LG flat screen no picture or sound
As your TV is three years old, I would suggest you contact your LG dealer to arrange an engineer to call to do a software upgrade on the it. The current software will be out of date & if you are connected via the HDMI connector then this can give audio/video problems.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
LG TV LCD 47LF65 makes a strange noise
It should make a little noise, but if it is annoying then it is probably an issue - this is most likely the power being reduced to the inverters when the birightness is turned down. Could be a noisy coil on your power board or a capacitor may be going bad and changing value. I would look for any swollen capacitors (a bump on top, bursted or swollen sides) on the power board.
Jan 07, 2009 | Televison & Video
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
