Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Weathermaker SX (model 58SX100)
My furnace is intermittent. The thermostat "clicks" telling the furnace to come on. Then the induction motor will come on for 10-15 seconds and then just goes out. After some resets the furnace will come on and light off normally and run just fine - until the next time. Often we will wake up or come home to find out the the furnace has not come on. We reset it and usually it will come on, but occassionally it will again turn on the induction motor for a few seconds and then shut down. The tech has looked at it twice and can't figure it out. Thinks it might be the burner control unit. Filter clean, no codes available (this system doesn't have it). Hunter thermostat.
  • rclatter Feb 04, 2009
    Okay I took of the tubing from the inducer and there was a little water in it and there was a low point so I shortened the tube and it worked like a charm for a couple of weeks. Now it has started back again. I rechecked the tubing and it appears obstruction free.
    I noticed that the inducer blower comes on for about 10-15 seconds but I get no pilot light and the inducer motor shuts right down. After a few resets the inducer comes on, in about 10 seconds I hear a tick, tick, tick (which I assume is an ignitor?) and the pilot light comes on and the furnace works like a charm...until the next time. The flame is blue and appears strong. So it appears the problem is that the pilot does not light (it does not stay lit constantly like pilots used to do on mom's old gas stove I assume that is correct). I hear no tick, tick, tick the times it just goes out - so the pilot light "ignitor" if there is such a thing does not try to ignite the pilot.
    Any ideas? Thanks in advance for all your help.
  • corniew Feb 05, 2009
    I'm having the exact same problem. My furnace just ran for 6 days straight with no problems but just went down again. Open/Close bottom door to reset after 5 min timer is finished ID fan comes on for 10 sec then goes back off.
    Scholar:
  • 144 Answers
There is a small tube that comes off the inducer for cracks or water. If there are cracks then the pressure switch that it is attached to may not be closing all of the time. Also sometimes you can get water in that tubing which will also cause the pressure switch to not close. If thats the case shorten the tube so there is no low droop in it where water can collect. Another thing that I would do is disconnect the tube at the indicer, take a straightened out paper clip or stiff wire and poke it in the nipple on the inducer to make sure it is clear too. Let me know if any of these work. There may be other things we can do.
Posted on Jan 19, 2009
On my carrier Model 585SXA100-J6 furnace, the gas pressure must be adjusted about once a year or else the pilot goes out. If you remove only the top service door on the furnace and look through the peep hole as the furnace starts, you can see if the pilot lights. If the pilot does not light,or does not stay on, the furnace will run a blower to vent the gas from the combustion chamber, which is why the furnace appears to run for a few minutes after a failure to ignite. In some cities gas pressure varies with the season and with demand. If the pilot does not stay on, a service person can adjust the pressure by turning (slightly) the larger of two slotted screw adjustments near the gas shut off valve that is in the furnace. The goal is a pure blue flame.
In the lower part of the compartment that is revealed when you remove the top service door is some PVC plumbing and a small tube that runs down through the front and bottom of this compartment. This tube must not become clogged. If it does, water builds up in the air intake plumbing. My furnace is old enough so that some plumbing in this area leaks even with the tube free of obstruction. Check for water in this area. To me, it looks as if considerable disassembly is required to fix this plumbing, so I'm going to call the pros. One main leak is from a seam in the black plastic chamber that hooks to the PVC air inlet. The symptom that seems to be associated with this problem for my furnace is that it runs fine for about 10 minutes but shuts off too soon.
Posted on Feb 02, 2009
  • 3 more comments
  • tashiro Feb 05, 2009
    Response to the comment by Rclatter than sometimes his pilot does not ignite
    I think to get a knowledgeable technician that you will have to call the official Carrier dealer since this is not an run-of-the-mill type of gas furnace.
    You are correct that the pilot does not stay light all the time. I haven't tried this, but I think the inductive pickup lead of an automotive timing light would detect whether the wire going into the combustion chamber was firing a spark to ignite the pilot. The type of timing light that has its own batteries would be perfect for this test. Some automotive multimeters also have leads with inductive pickups. It is like the familiar automotive question of "do you have spark".
    Even if you have no spark, you should still check gas pressure. I don't know if the control unit is smart enough not to fire the spark when it detects low gas pressure, but it might be. The slotted control farthest from the blue shut-off value inside the furnace can be used to adjust the gas pressure to the pilot. The fact that the pilot burns with a blue flame does not prove that it wouldn't burn even better with more gas.
    I had the following unusual experience with poor gas pressure. The sidewalks, sewer lines and gas lines on my street were torn out and replaced. Just after this I had a problem getting the pilot light to ignite. A city worker verified that there was adequate pressure at my gas meter. I called the company that installed the furnace. They found the pressure was low. At the junction to the meter they found that a fragment of plastic had lodged in the line. It was a cap of the type that is put over the end of gas lines to protect the threads during shipping. I suspect this had blown in from some of the new gas line was installed.
  • tashiro Feb 11, 2009
    Further response to Rclatter:
    The audible ticks don't correspond to an event involving the gas when my furnace starts. The pilot lights silently about 15 seconds after the small blower starts. About 10 seconds after the ticks is when the main burners turned on.
    If you Google on "Carrier 585SX" you can find links that discuss the sensors and circuit boards on this furnace. doityourself.com had a lengthy one:http://forum.doityourself.com/gas-oil-he...
  • tashiro Feb 10, 2010
    My furnace again had a problem with the drain. The symptom was that the inducer motor would start, the pilot would light, but the gas valve that controls the main burners would not stay not. I could hear it clank on and off rapidly. The problem was the drain tube from the heat exchanger. If you take off the bottom door of the furnace, you see two drain tubes go into a what looks like a short length of PVC pipe. Out of the middle of the pipe a single drain tube exits downward. The tube on the upper right goes to the combustion chamber. All the tubes seemed to be open, but when I took this tube off, water flowed out of it. I am able to run the furnace fine with this tube emptying into a jar. I think something in the PVC assembly needs to be cleaned or replaced. The lesson: just because the bottom tube runs freely, this doesn't mean that your furnace is draining properly. Water backing up in the tube from the heat exchanger could be detected in the nipple where the vaccum hose from the pressure gage is attached. I think this prevented the pressure gage from acting. When the furnace runs properly you can hear the pressure gage click soon after the inducer motor starts (The pressure gauge looks like a shiny disk, in the compartment of the furnace toward the right hand side).
    I incorrectly wrote that the tube on the right goes to the "combustion chamber". I meant "heat exchanger".
    "Pressure switch" would be the proper term instead of "pressure gauge".
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 turns off intermittently
You can find what the error code is by looking on the inside of the bloewr panel. If it is still there after all these years there is a code list right around the wiring diagram. If my memory serves me correctly it is a limit problem. But be for sure and check the code sheet.
Feb 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
When burners come on makes a swiching noise and then goes out and
The carrier sx series went through a number of control systems over the years. can you find the full model, and series numbers? They are located behind the door on the left side. (i.e. 58 sxc080-100 series100)
Dec 30, 2008 | Heating & Cooling
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier weathermaker sx 58 furnace
I have serviced these furnaces for 20 years and I can tell you most of these models did not have diagnostic lite on them. (although some did, especially if the control board has been replaced) The problem is most likely a bad 3 wire pilot. This will cause exactly what you describe. 2 things to consider though. 1, If you were to replace the pilot don't get a cheaper knockoff. In my experience these do not last long at all. Get the right one from a carrier dealer. It will cost more but be much more reliable. 2 What is the condition of the secondary heat exchanger? Most if not all of the sx series had issues with the secondary heat exchangers rotting out and leaking. If the furnace is out of warranty you would be much better replacing the furnace as the cost of replacing the secondary heat exchanger will probably be almost the same as a new furnace. ( those babies are EXPENSIVE!)
Dec 17, 2007 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
3,615 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
