Question about Kenmore Elite 45986 Front Load Washer
I am getting a dl w/an f error
I have a kemore he 4t model All I get is a series of beeps on the machine. I have unplugged it & reset the breaker with no prevail.
    President:
  • 373 Answers
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
-> Door lid is not closed completely due to interference.
-> Wash media buildup is preventing the lock bolt from extending.
-> Machine/motor control detects open door lid switch when attempting to lock.
-> Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Posted on Jan 19, 2009
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
No power
What is the model number of your unit?
Jan 21, 2013 | Washing Machines
My kenmore elite HE 4t washing machine will not start. error message dL. It has happen before but I was able to get it started and working for several weeks till now.
'dl' stands for Door Lock (Error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 23, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
I couldn't get the washer to start (HE 4T). It
DL stands for Door Lock failure, if your door isnt closing all the way, check to make sure your hinges are lining up and that one of the arms has not broken off on the door, there should be 2 arms going into the door lock. whats common on these is that the door latch has trouble unlocking so it is forced open and now the door latch mechinism is stuck in the locked position and cant re-open. problems with this lock opening and closing- 9 times out of ten, come from a main computer failure to send power to the door lock. this can be temporairily fixed by re-seating the door latch wire harness in the main computer, but its usually recommended to buy a new computer since this problem has been address on the new series of computer. there is no recall on this board at the moment. estimated cost $250-$400
Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
I pushed the start button and got some clicking noise, then I got an alarm sounding beep with a "F" flashing, then another alarm sounding beep with a "dl" flashing...which continued until I cancelled
If you give a specific model I could get a manual and see what i can find out but what i will do is direct you to the Kenmore questions line which is, (one last thing try unplugging the washing machine and then plug it back in maybe that will reset it, if you still get the error look below.)
Product questions
Call 1-888-KENMORE (1-888-536-6673).
also if you do not have the manual for the product you can obtain an online version here.
http://www.managemyhome.com/mmh/
if you look on the right hand side of the page you will see in bold letters.
Find Owners Manual
We've got manuals for every major brand in your home
just enter your model number in there and look through the manual for the troubleshooting section and then error codes.
Jun 01, 2009 | Kenmore Washing Machines
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Feb 14, 2009 | Kenmore Elite 45986 Front Load Washer
I have an error code on my Kenmoore elite HE 4t, it say dl f or f dl whatever and makes a clicking sound and will not turn on.
possible connection on main control pull top cover control rear rail try moving connectors in middle area of control if works try to shim connector snug other option replace control
Nov 27, 2008 | Washing Machines
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
196 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
