Question about Sansui Vintage Receiver 800, In Near Mint Condition With Original Owners Manual
When I switch receiver on a loud pop (snap) sound is heard from speakers
Looks like a sharp peak signal is released from capacitor or something That happens only in moment when I switch it on, after that receiver plays normal (there is no problem if I switch it of and on within 5 minutes) One more thing: receiver continues to play 5-6 seconds after switched of I'm not an electronic expert and will appreciate any suggestion and help ..... Thanks a lot ... Dragan
4 Suggested Answers
SOURCE: No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Posted on Feb 17, 2008
  • 757 Answers
SOURCE: Tone switch causing loud pop in speakers tripping protectiveRelay
The tone control on this one sounds like it is an active one and either using the low or high pass filter you would be boosting the higher or lower frequencies. Boosting the lower frequecies will be harder on the amplifier, in which case if you would like to use then you may need to connect speakers with a lower impedance or higher sensitivity.
Posted on Dec 12, 2009
  • 8546 Answers
SOURCE: I am fixing a sansui
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Posted on Dec 31, 2010
If you are still seeing meter deflection in received signals, it sounds like something in the audio amplifier went south.
Apr 23, 2014 | Radio Communications
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My tv made a loud popping sound. Now the bottom right 1/4 o the screen is black with different colored lines on it
Check for any bursted electrolytic capacitors on its main power supply regulator board. The sound you heard might be to this burst. Take care, and unplug the TV from AC mains supply wall socket, before opening and checking this board. See examples of bulged [bursted] capacitor.
Jul 10, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
We heard a loud pop... then saw a flash of light set off by the internal speakers. What causes this? Are these speakers out of phase? What's causes this?
These are rated peak 600 Watts... your amp should NOT be bigger than 200 Watts RMS per speaker cabinet driving these to prevent burning out the speakers. The pop MAY have driven the speakers to full excursion and temporarily shorted the speaker voice coil. Test the DC resistance of the speaker... if you find it is under about 3.7 ohms you have damaged the speakers and continued use may damage your amplifier.. Often people will unplug a guitar cable causing a loud pop in the PA system and that CAN damage the speakers if the amp is too big.
Aug 16, 2011 | Kustom KSC215H PA Cabinet
How can i get more power through 8 ohm speakers?
In addition to the impedance rating of a speaker, there is also a wattage rating. Ideally, power output of the amplifier should not exceed the power handling rating of the speakers. The input impedance of the speakers should match the amplifier output impedance for maximum power transfer (Rin = Rout where R is resistance in Ohms). Supplying more power or wattage to the speaker than it can handle will result in distortion, and if the output of the amp is high enough and present long enough, it will damage the voice coil of the speaker. Make sure that when comparing wattage ratings, you are comparing the same rating between amps & speakers. Watts can be expressed three different ways: "Peak", "Peak to Peak" and the industry standard "RMS". The relationship is such: an industry standard value of "70 Watts RMS" (70W RMS) equals "100 Watts Peak" (100W P) *and* also is the same as "200 Watts Peak to Peak" (200W P-P). Furthermore, there is no such thing as 200W "Music Power" (but is often expressed this way to inflate the RMS wattage rating (and usually is close to the P-P rating). A speaker is an electrical device, so most the things that happen to electrical devices when over powered can happen to speakers and amplifiers, too.
Increasing the signal source level (input signal to the amp via volume control) in an attempt to get more audio power to the speaker can overdrive the amplifier - resulting in "clipping". This is plainly heard as "muddied" sound. The otherwise loud, crisp, clean passages in music end up sounding garbled and unpleasant when an amplifier is over driven in this way. This can damage both the amp and the speaker.
Cheap amps with higher THD (total harmonic distortion) ratings sound worse than their counterparts with a lower THD rating - when all other variables are the same. You'll pay extra for lower THD values.
You might be able to make a speaker seem louder by positioning the speakers against a wall, on the floor, etc. Experiment; as it can make a significant difference in sound levels and low frequency bass sounds.
I hope this was helpful!
Jun 11, 2010 | Yamaha Emx62m Powered PA Mixer System
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Magnavox 37MF231D 37" LCD TV "popped" now won't turn on at all!
Capacitors tend to pop when they fail. Phillips LCD TVs have lots of problems with capacitor failures in their power supplies. I've got my 37mf231d apart on my workbench as we speak. Mine makes a whistling sound which I believe is either a solder fault or a bad capacitor.
A new power supply board is about $150 for that TV. The gamble, of course, is if the power supply took out something else when it failed.
Jan 16, 2009 | Philips 37MF231D 37 in. LCD Television
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Jan 26, 2008 | Yamaha HTR-5660 Receiver
Yamaha RX-V730 problems
I used to have a set of speakers with 'poly switch' over-current protectors (kind of a 'soft' fuse the size of a small ceramic capacitor) installed in-line with the speaker terminals. (Each speaker in an enclosure needed its own device.) The theory was they appeared as a dead short until their rating was exceeded, going open-circuit to protect the (assumed, more expensive) speaker element. When things 'cooled down' it returned to the former short status and the speakers came alive again. Testing the device with a decent drive signal (it worked), I noticed the sound 'strangled' and only a low-volume, higher-frequency component of the source signal was heard through the speaker. (So I guess it wasn't *totally* open circuit...) After a few seconds of signal removal (and reduction of source volume) the sound came back to normal. Here's my thought: Perhaps your speakers have these devices installed and the devices are operating accordingly. Of course, if the source signal is of a known low-volume, then it sounds like an amplifier component is failing on load. Especially if the speakers behave normally using another amplier. Cheers...
Jan 26, 2007 | Yamaha RX-V730 Receiver
Sansui Vintage Receiver 800, In Near Mint Condition With Original Owners Manual Logo
32 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
