Question about Toshiba 32BV700B 32 in. LCD HDTV
My toshiba 32bv702b screen is green when i play a dvd can u help
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Attempting to play a DVD on a Toshiba player but not able to get full screen picture on TV. Can you help with the problem?
A DVD plays in "Letterbox" format. To have full screen, the TV settings need to be changed to full screen, or zoom. Found in the TV menu of most TV's.
Read ya
Z
Dec 31, 2009 | Toshiba SD-K760 DVD Player
My toshiba SD 6100 dvd player is playing only blue screen
just tried with RCA or the hightdef. cables the one with Green bue and red.
Aug 24, 2009 | Toshiba SD6100 DVD Player
Green screen
I had the same problem, my TV had two SCART inputs - when plugged into one the DVD played green, when plugged into the other, it played normally. Have you tried this?
Oct 22, 2008 | Daewoo DVRS04 DVD Recorder/VCR
TOSHIBA 57 H 81 wont play 480p any more Green Screen
this happened to me once and what i found was that i had missed a defective component.. these parts need to be checked for ESR also check the solder connections....john
Aug 24, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 32BV700B 32 in. LCD HDTV Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
