Question about HP vs19 (Silver) 19" LCD Monitor
How do you dim monitor brightness
Pull up menu on monitor, but cannot adjust brightness...do not know how to do this.....
  • HP Master
  • 3,904 Answers
This can be done in the menu on the monitor. There should be a button that says menu. push that and sub menus will come up. There should be a choice for brightness. Most of the selections are then adjusted using the volume buttons Up or Down.
Posted on Jan 21, 2013
3 Suggested Answers
myjosh007
  • 530 Answers
SOURCE: Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Posted on Feb 26, 2009
SOURCE: Hpm-705 crt monitor fault?
switch prees no power on
Posted on Oct 11, 2010
LG W1943SE monitor dimmed
tried first with adjustment at set up menu, select the contrast and brightness and make some adjustment. if you can not get with adjustment i may say that one portion of the screen back light is not working. check for burnt connector at power inverter board or busted back light.
Sep 15, 2012 | Computers & Internet
19 inch lcd monitor has dimmed display
tried to adjust in the screen set up menu the brightness and contrast. if can not get with adjustment with very dim display replaced the back light ( cold cathode lamp).
Jul 22, 2012 | Computers & Internet
Deem light in display
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1.Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2.Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3.Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4.Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful.
Aug 26, 2011 | IBM ThinkPad R52 Notebook
Dark picture on monitor
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
Monitor dim
Have you tried pressing the menu button and adjusted the contrast/brightness controls. Buttons located on the monitor.
Jul 25, 2010 | Acer AL1716 17" LCD Monitor
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
I would like to know how to dim the light /screen on acer p221w monitor.It is very bright and i would like to know how to dim it
You should have some buttons on the front of the monitor, one of them is probrably a menue button which should allow you to adjust alot of the monitors settings from within there.
You can always download a manual by googling your monitors model number for exact instructions.
Nov 08, 2009 | Acer AL1916W 19" LCD Monitor
My screen is too bright and hurts my eyes. How do I dim it a little?
he on the monitor you can find small buttons ,, you can just go select menu button from there select brightness section,, all this appear on display screen,, once click on button.. where u can adjust
Oct 05, 2009 | Acer V193w LCD Monitor
I cannot adjust the monitor brightness, it's too dark..
Since this problem was posted generically.. Monitors, whether they are the old tank style CRTs, the newer flat panel LCDs or the newest LEDs, all have 'Brightness' controls. All are typically marked with what looks like a bright, or radiant light bulb, usually offset to one side, to show that "adjusting the ?? that way" will brighten the screen. Most LCDs are now Menu Driven, so looking for a button that says "Menu" is your starting point. You will need to find your adjusting control and the 'light bulb' to figure out which way to brighten or dim your screen. Once found, adjust to eye pleasing brightness. If your brightness is at 100%, you are on your way to needing a new or used monitor. Typically, there is no Brightness settings in the operating system. Your enhanced video card maybe doing it to you, They usually have their own control center and the types of abilities vary greatly. If you hav a friend that can loan you a monitor, borrow it to test at least the output your monitor is receiving. That will tell you whether you are having a problem with your video card or your monitor.
Aug 18, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
Too bright
I just bought an Acer 19 inch this morning and I am assuming you have the same controls on the bottom of monitor. On mine I push the menu button twice....the left arrow once to select the brightness slider.....push the menu button again to turn slider red and active...then use your left or right arrows to adjust brightness...afterwards you use the menu to get you back to the exit button and that's it....I hope Don
Dec 07, 2007 | Acer AL2016W 20" LCD Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
91 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
