Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
How do I connect my laptop to my Mitsubishi TV model WD-52327 to my laptop?
Streaming Netflix from laptop to TV...how do I connect them?
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 40 Answers
SOURCE: Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: WD-52327 Red Light Problem
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Posted on Jul 16, 2008
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
asnowman
  • 788 Answers
SOURCE: status lamp lights-up on front no picture
The lamp is not that exspensive you should be able to get one for around $150 and you can replace it yourself.
The lamp can be bought as a lamp or you can order the entire cartridge, I would suggest the cartridge, unless you are handy at taking things apart as the cartridge can be tricky to take apart without breaking it. The only difference will be the cost. It is your choice. The Mitsubishi part number is 915P020010
You can google this and find many places to purchase the lamp or cartridge on line.
Replacing the Lamp Cartridge Tool needed: Phillips screwdriver
1. Turn the television off and unplug the AC cord.
2. Remove the front speaker grill by gently pulling on each side. The grill will snap out.
3. Using a Phillips screwdriver, remove the three screws (one on the left and two on the right side) that hold the recessed plastic cover in place.
4. Remove the plastic cover and set aside with the screws.
5. After removing the cover, you will be able to see the lamp cartridge. With the screwdriver, loosen the threes crews of the cartridge. The three screws will not completely remove.
6. Gently grasp the metal handle and pull straight out (towardsyou).
7. Insert the new lamp cartridge securely into the TV. Do not touch the glass surface of the cartridge.
8. With the screwdriver, tighten the screws on the lamp cartridge.
9. Replace the plastic cover and screws.
10. Snap the speaker grill back into place by pushing it into place on each side with the palm of your hand.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 01, 2009
Testimonial: "thank you very much you told me me exactly what i needed to know your the man thanks again louis"
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
How to streamline movies from Netflix to Mitsubishi
If your 60 inch TV is a "smart TV", you need to go to setup and enter your router's identification number. If it is not a "smart TV" you need to add a streaming media box (such as Roku or similar product) or "smart DVD" player with Wi-Fi feature to your system.
Jan 02, 2014 | Mitsubishi WD-60738 60-Inch 3D DLP HDTV
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
I AM CONNECTED TO FIOS VERIZON. MEDIUM HIGH SPEED. IS THERE A WAY TO GET NETFLIX HOOKUP THRU THE WIRELESS ROUTER I HAVE FROM VERIZON to my tv..
There are multiple ways to stream Netflix over a high speed internet connection. You will need a device to run the Netflix streaming - your choices are Playstation3, Wii, Xbox, Tivo Premiere, or a Roku box. You could potentially use a computer connected to your TV to stream it as well, but the computer would need the appropriate outputs to hook up to your TV.
Mar 15, 2011 | Mitsubishi WD-60737 60 in. HDTV
Do not remember code to unlock tv its a Mitsubishi WD-52327 52 is there a way to reset it
Thanks for visiting FixYa;
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
If that does not work unplug TV for 5 minutes, or you have bad buttons on your control panel. You can disconnect the board from the front of the TV. Take off speaker grills, remove cover(5-6 scews), unplug cable to control board. The TV will work with remote but not manually.
Good luck, Big Irish.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
