Question about Humidifiers
I have a sunbeam ultrasonic cool spray humidifier model # 681. it has been discontinued and is NLA. where can i find a filter. the machine works great, but no filter!!!
I tried to get the manual from sunbeam. the product comes up, says nla. the gal i conversed with sent me to you!
5 Suggested Answers
  • 123 Answers
SOURCE: sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Posted on Apr 21, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: Sunbeam Ultrasonic Humidifier SUL495 quit working
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
Posted on Dec 04, 2010
Sunbeam ultrasonic humidifier model 694
i have a sunbeam humidifier model 694 i want to know how do i use it
Feb 04, 2014 | Humidifiers
Sunbeam Ultrasonic Humidifier SUL495 quit working in first week. What may have happened.
Nov 29, 2010 | Sunbeam Ultrasonic Humidifier
How do you clean the 705 ultrasonic humidifier
You can soak everything but the motor in bleach or vinegar water. Rinse well with HOT water.
The filter is disposable, cleaning doesn't help with them.
Nov 18, 2009 | Sunbeam Ultrasonic Humidifier
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
Sunbeam ultrasonic cool mist humidifer model 700
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Humidifiers Logo
150 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
