Question about Seiko 0512039FA Wrist Watch
I have a seiko v172 solar watch and the second stops every hour.How do you stop this?
The second hand stops every hour.It's driving me crazy!!
5 Suggested Answers
SOURCE: My watch constantly stops
check for automatic winding offcentre disc clutch mechanisum fault
Posted on Aug 24, 2009
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
  • 823 Answers
SOURCE: I have purchased a new
if the resistance hasnt been reached via water depth or height in air it should be fine. if the incriments havent changed by five mintues after charging seek repair via the store you got it from or the Seiko customer service at
SEIKO Corporation of America - Service Center
1111 Macarthur Boulevard, Mahwah, NJ 07430, U.S.A.
Tel:+1-201-529-3316
Fax:+1-201-529-4525
E-mail:custserv@seikousa.com
Web:http://www.seikousa.com/ chances are it is the mechanism that alternates the current and it is normal.
Posted on Apr 05, 2011
  • 2501 Answers
SOURCE: I have purchased a new Seiko kinetic SUN007 mens
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Testimonial: "Thanks, will do."
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
Jan 04, 2017 | Seiko Watches
My Seiko railroad approved bracelet solar power watch stopped, how do I get it running
the advice is to buy a new one, no one is fitting the batteries to these, due to the high part cost.
even if it's in warranty, seiko just send a new watch out.
Apr 23, 2015 | Seiko Watches
Just purchased the men's Citizen's Eco Drive Nighthawk (Black) ca0295-58e and the second hand on the watch is not ticking. I previously set the date and the hour and minute hands have moved, but not much....
Put the watch in any form of light for some time. Sun is best but not necessary. When the second hand stops running, it is a sign that the capacitor is low. The eco drive is a solar powered watch. When exposed to light, it converts the energy from the light and stores it in an internal capacitor which is really a battery that will last about 20 years.
Nov 09, 2017 | Citizen Watches CITIZEN Mens CA0295-58E...
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Seiko watch stop watch needs resetting
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
Hour hand stops at 10 oclock
Could be
1, Need New battery
2, Hands touching & blocking each other
3, Watch required cleaning / overhaul for movement
any expert watch maker will do that or if you in chicago bring it to us
we do repair and provide free estimate
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Seiko SNA311 Wrist Watch
Aug 24, 2009 | Seiko Watch SNXJ89K1
Seiko 0512039FA Wrist Watch Logo
346 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
