Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Screen cost? would anyone know what a screen might cost for a pioneer projection sd-p5191-k
    Problem Solver:
  • 8 Answers
Hi my name is Rocky I'am new I live in windsor on their is a person I know here who has lot's of them if you remove your's and bring it to him he will give you the exact one $40.00 I have the same problem but I don't know how to get mine off can you help with this problem thanx rocky
Posted on Jan 24, 2009
What size mirror pioneer sd-643hd5
All the mirrors are of special construction: a normal mirror will not function or produce a good picture.
Consider looking online (GOOGLE) for one of the several vendors who sell replacement mirrors by brand/model number or contact Pioneer to see if mirror available.
There are also people parting these sets out on Ebay from time to time.
Good luck and if you have questions let me know.
Steve
Feb 29, 2012 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Would anyone know what a screen might cost for a pioneer projection sd-p5191-k
I'm not sure which screen you need so both are listed below:
part number Description Cost
AMR2835 Lenticular Sheet $306.95
AMR2836 Fresnel lens screen $430.95
Hope this helps,
Dan
Jan 19, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Removing the protective screen on our Pioneer SD-532HD5
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Nov 11, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Need to help accessing convergence IC's on Pioneer SD-P5191-k
these sites should show you good examples
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 09, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection sd-p403
The screen looks like a bad 3D movie without the glasses. Anyone know how to fix this?
Jan 01, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer SD-533HD5 - Red bowing at the bottom of the screen
Convergence amp. IC's on power supply PCB need replacement.
Part # STK392-110 sub to upgrade STK394-160E. I use Hitachi ,
no re-calls! Not advisable to use generics......
Worth repairing unless you are ready for a change......T.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
SD-P5191 Pioneer control inputs lock after startup
Pioneer say Main CPU bad. Replace and install capacitors, diodes and shield plate. See SI Bulletins for more info.(SI-a48032-G)
Apr 14, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
43 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
