Question about HP DeskJet 5150 InkJet Printer
Changing ink cartridge
Every time we go to change an ink cartridge, this printer decides is doesn't want to print. This is so frustrating! I have called HP, and they try to say it is my connections. How can this be when I just printed pages just prior to changing cartridge. Oh, it doesn't matter which cartridge is changed. This happens with either. Now a couple days from now, they dang thing will decided it is time to print again! In the office, this is frustrating to have to copy items to CD, go to another desktop to print! Oh, btw - this is a "stand-alone" printer! I am the only user in the office! I have upluged the power supply to the printer, let is set a couple minutes - then plug back in - no difference. I have unpluged the USB cable from the printer, also let this sit, repluged - no change! I have unpluged bothe cables at the same time - let both sit - replugged both - still NO CHANGE! Now what do I do? Do I change printers? Get another brand?
  • Robbie Wilson Jun 26, 2007
    YES,,,, like I said above.. it does not matter which cartridge is changed... it's like this thing has a mind of it's own!
  • Anonymous Mar 18, 2009
    I have the same problem. It worked after I changed the cartridges, but then the next day the "wrong cartridge blinking lamp signal appered". Dose not work to print anything now. Frustrating when nothing works.
  • 84 Answers
Did you take the little plastic strip off of the ink cartridges that protects the connectors?
Posted on Jun 26, 2007
SOURCE:
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
5740 acts like it's printing, but no ink on paper
Since it's trying to print, the printer probably just needs cartridges. The ink can dry in the nozzles with age and disuse and clog them.
Before you splurge on new cartridges, try getting them going. (This assumes there is some ink left in them.) Take the cartridges out of the printer, wet a layer of paper towels about 1/8 inch thick, and whack the nozzles against the wet surface a few times. Check every few whacks to see if you're getting any ink flow. Repeat until you see some ink on the towels and on the nozzles, or until you decide it's futile. Often this dislodges the clogged ink and opens the nozzles, and buys some extra printing time. But you're probably going to want new ones soon anyway.
Apr 08, 2010 | HP Deskjet 5740 InkJet Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
[email protected]
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP Photosmart D5069 does not print. All the cords are connected properly but when I go to print something nothing happens. When I look at the status it just says Error-Printing
If you have recently changed ink cartridges and used an off brand cart. you can get this response.
HP printers can be real picky about whose ink cartridge you use. They usually have a 3 cartridge memory. That is they remember the codes from the previous 2 cartridges , wanting the new one to be of the same (HP) type. There are various workarounds. Depending on the model there may be some differences. Usually they all involve simply removing and re installing a cartridge 3 times to brainwash the little memory chip. Sometimes it requires powering off and on between changes. It is a lot of frustrating repetition but HP wants to sell you INK.
A somewhat simpler cause of the print failure is often dirty contacts in the back of the cartridge or of its seat bracket. Easy clean is Q-tip and some Alcohol. Not to vigorous and dont leave any fuzz behind.
Good luck
Apeal
Aug 21, 2009 | Office Equipment & Supplies
HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
No Yellow Or Cyan Ink
Hi do the following and hopefully it will help you. If it doesn't then you have a fault carriage or main PCB.
  • Remove ink Cartridge
  • With a soft cloth wipe clean the gold contacts on the carriage unit and the same on the ink cartridge
  • reinstall the ink cartridge
  • Click start
  • Select printers and faxes
  • Right hand click on the printer icon
  • Select Properties
  • Click on Services Tab
  • Click on clean print heads
  • Then click on Prime.
Hopefully this will work
Thanks J
Dec 01, 2007 | HP DeskJet 990cxi InkJet Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP DeskJet 5150 InkJet Printer Logo
298 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
