Question about HP OfficeJet 7310 All-In-One InkJet Printer
Cerrage jam the printer moves to the left then when moving to the right makes a grinding noise & locks up.
    Scholar:
  • 97 Answers
this issue could little complicated, that happens becoz there would be a lubricating coat on the carriage rod to it to move freely. if thats gone u would have this kind of issue. try apply any lubricator, make sure u dont spill it inside the machine, just apply little bit,it should resolve the issue.
Regards,  raj_p5983
Posted on Jan 21, 2009
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
The power light is flashing and the printer makes a grinding noise and won't print. There was a paper jam that i had to pull out prior to this issue.
Hello According to HP, follow these steps for resolving the issue
Remove the rear access door, or the automatic two-sided printing accessory, and check for any paper jams or paper obstructions. Remove any obstructions. Check to make certain the carriage is on the right side of the printer. Rotate the rear paper guide rollers upwards five times, then downwards four times. If the rollers will not move, open the top cover and slide the carriage to the right (if it is not already there and if carriage can move). Try to roll the rollers again while pushing the clutch in. If the rollers do not move, continue on to the next step. Figure Location of the clutch c00040832.gif Replace the rear access door accessory, or the automatic two-sided printing accessory. Close the top cover. Plug the power cable back in. Turn the printer on, and replace the cartridges if possible. If the carriage moves, but there is still a grinding noise, there may be a paper feed issue. If the carriage will not move, then it is a carriage stall issue. After installing the cartridge, if the printer has a solid power light, perform a self-test on the printer. Hope this helps, if so do rate the solution
Jan 02, 2011 | HP DeskJet 3650 InkJet Printer
Left rear tire locks going forward but not in reverse
There is probably parts of the bearing that are rubbing against each other and jamming, lift the rear and move the wheel in and out (like shaking), also spin the wheel and listen for grinding noise, if it moves or makes irregular noise, your bearing needs to be replaced, if everything is tight than check your brake shoe pads, a dislodged piece may be jamming between the shoe and the drum(it happened to me before!).
Dec 14, 2010 | 1995 Toyota Camry
The printer cartridges do not move from left to right. makes a grinding noise
The mechanism on which the cartridges slide has a strip and wheels on both sides of the printer... one of these things causes the jam.
Try maneuvering it manually and see if the problem solves.
Jul 18, 2010 | HP DeskJet 5550 InkJet Printer
Error message with grinding noise as driver cycles
Make sure the little spring loaded side fingers that grab and hold the cart onto the printhead are not broken. With the unit off, slowly move the carriage all the way left then right to check for a good belt and free movement. Take the carts out and tilt the printer back and forth to see if something has broken off inside, check to make sure nothing has fallen into the paper rollers from behind.
Jun 06, 2010 | Alps MD 2010 Thermal Printer
I replaced my color cartridge on my HP Photosmart C3100 series printer and now it is making a grinding sound, but prints perfectly fine - what is the problem?
You would want to try and reinstall the print cartridges. It is possible that something is just stuck that is why you are hearing the grinding sound.
Let me know.
Apr 06, 2010 | HP Office Equipment & Supplies
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Device maintenance issue
Check with a torch for a jam, small paper or foreign matter, use a torch, check very carefully and make sure you check paper feeder, and near carriage.
Apr 02, 2007 | HP Photosmart 3310 Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
