Question about Mitel Superset 4150 Phone
Sync massage displayed on the display and set is not working.
    Scholar:
  • 95 Answers
This phone is a digital phone and requires connection to a digital system commonly called a "key system". If you have removed it from where it was connected and tried to use it at home or somewhere else it will not work. Most home or normal phone jacks are connected to your local provider directly and is what is called an analog system. The 2 are NOT compatable without an interface device. If it is connected to a key system then thier is a problem with the port on the Mitel keysystem that goes to the jack you are plugging the phone into and you will need a technician to fix/rewire this onsite. Hope this helps you. A manual for your phone can be gotton here: http://www.octelephone.com/4150user.pdf
Posted on Mar 29, 2009
3 Suggested Answers
  • 95 Answers
SOURCE: waiting for sync
  • 95 Answers
SOURCE: massage on display "sync"
This phone is a digital phone and requires connection to a digitalsystem commonly called a "key system". If you have removed it fromwhere it was connected and tried to use it at home or somewhere else itwill not work. Most home or normal phone jacks are connected to yourlocal provider directly and is what is called an analog system. The 2are NOT compatable without an interface device. If it is connected to akey system then thier is a problem with the port on the Mitel keysystemthat goes to the jack you are plugging the phone into and you will needa technician to fix/rewire this onsite. Hope this helps you. A manualfor your phone can be gotton here:http://www.octelephone.com/4150user.pdf
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
Auto sync appears to not work properly
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
May 19, 2009 | BenQ PB8250 Multimedia Projector
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Waiting for sync
Jan 19, 2009 | Mitel Superset 4150 Phone
Massage on display "sync"
Display sync out of range
start the computer in safe mode.
go to control panel>>display>>settings>>advance.
reset the screen refresh rate back to 60Hz under the monitor tab.
Nov 17, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
'the setting could not be opened' this massage is displayed when select 'setting'
You need to upgrade the firmware of ur handset which includes O.S also. but it is hard to find the firmware now as this product is stopped by Motorola.
Feb 23, 2008 | Motorola Mobility MPx220 Pocket PC
Error
while power on display massage eerror c00e0402 . how to solve problem?
Oct 23, 2007 | HP PSC 750 All-In-One InkJet Printer
Mitel Superset 4150 Phone Logo
111 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
