Question about Dryers
Can a cable tracker be used to trace live 110 lines?
Using a cable tracker I bought from Harbor Freight seems to work with 110 wiring when the circuit breaker is turned off, but can it work safely with the CB turned on. If not, could a capacitor be inserted between the tone generator and the hot wire for isolation? I am trying to find a break in the wire that leaves several receptacles cold while the rest of the circuit is hot. The cable tracker seems to follow the wire all the way to the cold receptacles as being continuous, but voltage measured is zero.
  • Bud Taylor
    Bud Taylor Jan 05, 2013
    I have figured out a way to inject the warbling signal into a hot electrical by make an antenna with simple 4 ft long piece of lamp wire and a male plug. I cut one lead to the plug at a point right at the plug to destroy conductivity. I attached one lead from the sender to the far end of the severed plug wire. This can be plugged into a receptacle at any point in the circuit and detected with the receiver at other points of the circuit wiring. I.e. the two wires of the plug wire become inductively connected to transmit the signal into the circuit wire. The plug can be reversed to test the hot side and ground side separately.
  • 999 Answers
SOURCE: I've got a kenmore model# 110-60722990 that has
Check the thermal fuse on the blower housing in the back.
Posted on Jun 30, 2009
  • 1922 Answers
SOURCE: Elec dryer, no heat case
check your center NEUTRAL connection to the element,sounds like your losing it somewhere,certain units rely on the neutral to operate the element on certain cycles to dry, the neutral carries the imbalance current load and the wire gets hot and will get brittle and break
Posted on Sep 24, 2009
  • 1922 Answers
SOURCE: 2 12/2AWG = 1 10/3AWG
yes, with a double run of 12-2w/ground you'll end up with 2pairs of 12 for your 2 hot phases(you will need to mark one pair red to substantiate the 2 different phases) and each 12 gauge wire will carry 20 amp each alone, then you'll have 2 pairs of 12 with white insulation white for neutral is fine but the other pair for the safety ground will need to be marked or painted green where ever visible per N.E.C. i.e. main panel or dryer receptacle or hardwired into the unit itself,use 10-3w/ground its cheaper in the long run and you dont have to run a doubleheader
Posted on Sep 27, 2009
Testimonial: "dmftrucker was patient with me... it took a bit for all to sink in but I got good technical, code based advise from him. Thanks a Lot! kk"
  • 6784 Answers
SOURCE: no hot air blowing LEB6200pq1
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE(If the Thermostats and fuse check out ok, replace the element. Element failure is uncommon but, it may fail in certain cases))
(Make sure the entire venting assembly is not clogged as well)
Posted on Nov 06, 2009
  • 619 Answers
SOURCE: the dryier runs but stop heating
Check the red wire coming in from the timer to the motor switch to see if you have power there. If you have power going into the motor but not out to the heater you need a new motor.
Posted on Jan 29, 2010
My porter cable belt sander 352vs just went dead. I was using it for about 15 minutes and then it died with no warning signs. I subsequently plugged it into a variety of outlets thinking that was the...
Unplug the the sander open the plate to the power cord check for broken wires. Use a Digital Multimeter on the cord to find hidden broken wires in the insulation, if the power cord checks out fine it is in the motor or the switch check the switch and wires with the Digital Multimeter if the switch is fine it is in the motor replace whatever you find that is bad.
Sometimes Harbor freight tools will give away 7 Function Digital Millimeters just for visiting their store check the ad in the link below.
Harbor Freight Tools Quality Tools at Discount Prices Since 1977
Billy from Hayward.
Dec 22, 2014 | Sander Tools & Hardware - Others
I need to know the voltage required for operation of Liftmaster 975LM Laser Parking Assist
try looking on the motor mechanism and it should be marked as to weither its 220 or 110 and as to if its AC or DC as most american things seem to be DC .apart from that i have no idea without having a good look myself but i would imagine its mains powered unless it has a external transformer ,the thickness of the wires on the motor is another good clue as 220v AC will have thiner wires as ohms law specifies the amperage capacity of a given diameter cable .Or was it faraday anyway whoever it was the smae applies now as it did a 100 years ago Been a long time since i was at college so my memory is now suffering from old timers
Jan 21, 2012 | Cars & Trucks
Wire keeps jambing in hose
Make sure you are using a high quality brand of wire. Don't use the junk Harbor Freight sells. Use Hobart or Lincoln Electric. Also make sure your wire feed setting isn't too fast.
Mar 01, 2011 | Clarke Power Products Clarke 130EN...
Central pneumatic. It will not compress to more than 20 pounds. Doesn't seem to leak.
Central Pneumatic is a Harbor Freight Tools brand, and they are usually pretty good about working with you if you need to do an exchange. Get ahold of your local Harbor Freight store or go to their website for more info.
Aug 18, 2010 | Air Tools & Compressors
Everytime i put a fuse in for the turning signals it pooches the fuse everytime? I have a 1996 jeep cherokke
dont wanna ask a dumb q but have you replaced any of the other bulbs lately had some one say no 4 or 5 times and after hours of searchin wrong bulb for the socket seems to be common lately they all look the same
Jul 07, 2010 | 1996 Jeep Grand Cherokee
My son bought a 1987 2 wheel drive 4 cly. the lights did not work he replaced a fuse and several lights they worked fine untill he drove it about 10 miles and then the lights quit again. he drove it home...
It seems to me you want to follow that broken wire to find out where is goes, on the hope it powers the lights?
When you have a short circuit like this, The easiest way to do it is to put an oscillating pulse down it, and then trace for it with a signal receiver and speaker. Harbor freight sells the pair for tracing phone lines, for under $50. You could make your own with a flasher to generate, and an inductive ammeter, galvanometer, or a coil and speaker. Or you could just assume it has to go to the fuse block, ignition switch or something big and important, so you could look until you found what used that size and color wire. Of you could let it get hot and feel the heat or wait til it shrivels and use that to identify it. But it is probably cut through its insulation where it goes through the firewall. Although I had one car where the accelerator cable sawed through the wire harness.
Jan 20, 2010 | 1997 Nissan Pickup
I own a 16" wood planer and I cranked the wheel down a little to much and it seems like I have broke the shaft on the blade. The name on the planer is central machinery but i cannot seem to find that...
Harbor Freight is the dealer for Central Machinery tools. Take your model number, and look it up on their website. They have all the parts available by mailorder. I have a electric jack hammer and have ordered parts for it, as well as a wet tile saw. Hope this helps.
Nov 02, 2009 | Jet 16" Wood Planer - 708531
Wire new motor on a harbor freight 1 in 1 machine
The wiring diagram is on the motor name plate. It usually will only require you to hook up the hot and neutral (black and white), and the ground (green)
Sep 17, 2009 | Drills
My Kenmore 80 series dryer is no longer heating up. The dryer it self is running, we have been able to air dry the clothes, but no heat
If all controls seem to work normally, except that no heat is produced (and is an all electric unit--not gas), then likely the heating element is burnt out (has a break in the wire that heats up and glows, like in your toaster--though the heating wire can sometimes be within a covering metal like your electric range burner, and the break not visable). This is a commonly replaced part; it can be tested for continuity (no break in the wire) with a VOM (Volt Ohm Meter--$2 w coupon at harbor freight this week I noticed) where you set to ohm-resistance (to arrow with + sign if shown and will beep when probes are touching to show a complete circuit) (number would be the same as probes touching, but since resistance wire [to make the heat], there will be some number but not close to that of leads just held not touching anything) or the piece of wire, flashlight bulb, and flashlight battery test (casing of bulb to end of element, battery to end of bulb, piece of wire to other end of battery and on to other end of heating element), where if bulb lights then no break in element (though occasionally wire break can be disconnecting only when large dryer current is applied).
Of course unplugged when do all this testing.
The dryer "working" as it is, is using 110 volts (the controls and the motor) and is separate from the heating circuit which is using both 110 volt sides of the outlet, to equal 220 volts.
Of course, you should check that the connections are solid, and if you have the VOM, you could even use the VOM set to 600v AC to check that the outlet is delivering 110v on both sides of the plug and 220v between the two hot leads (usually black and red, with white the neutral which eventuall connects to ground--if a 4th lead, it is the cabinet ground--usually green or bare).
... and make sure when looking in the cabinet, that there is no build up of lint which can cause the overheating and heating element failure in the first place.
Aug 10, 2009 | Dryers
Dryers Logo
Top Dryers Experts
