Question about Olympia InfoGlobe Caller ID
I can only see half of the readout on my mo, ol3000.2
What city is half way between Racine wisconsin and Oklahoma city Oklahoma?
Looks like St. Louis, Mo. or Kansas City...why don't you google it.
Mar 17, 2015 | Cars & Trucks
What is half way point from cassville mo to buckner mo
Looks like Nevada, MO if you take I-49.
Nov 30, 2014 | Cell Phones
Half way point between Holmen, WI and Branson, MO?
Decatur junction IS 35 j13 and route 34 between Decatur City IA and Van Wert IA.
Oct 22, 2014 | Cell Phones
Eng09 f450 diesel engine assyine removal
get instructions from a light duty truck dealer who can give you a detailed readout about it..most regular dealers wont have this..it will need to be a bigger truck dealer..like broadway ford in st. louis mo..
Dec 08, 2013 | Cars & Trucks
Panu poh ba isave sa m.card ku ang themes download ku poh sana reply poh sana kau agad
unang una, anong model ng cp mo? pangalawa, nokia ba toh? pag nokia yan ganito ang pag save ng themes sa memory card.
1. tanggalin mo ang memory card ng cp mo
2. kung meron kang usb card reader, ilagay mo ang memory card mo dito
3. ikabit mo sa usb port ang card reader
4. pagkatapos madetect ng pc or laptop mo ang card, buksan mo kung saan folder mo naisave yung na download mong theme sa laptop o pc mo.
5. copy and paste mo lang yun sa memory card
6. ilagay mo ulit yung memory card mo sa cp mo
7. tapos pumunta ka sa menu>tools>file manager>select mo memory card
8. makikita mo dun yung mga natransfer mong themes and pindutin mo yun
9. tapos install mo and follow mo na lang ang instruction sa cp mo
10. pagtapos mo install, delete mo na lang yung theme kasi naka install na un sa cp mo.
11. pde mo na ding di delete para back up.
Nov 04, 2010 | Cell Phones
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
Nov 17, 2009 | 2001 Pontiac Sunfire
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Canon Image Class 6530 LCD readout is off center
To reset LCD, turn off and unplug unit for a few minutes. Then Plug it back in, turn it on, and it should be OK.
Go here to see this fix:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=268&modelid=13170
Jun 06, 2008 | Canon imageCLASS D760 All-In-One Laser...
Altec Lansing im600
GET IT REPAIRED IT HAS A TECHINICAL FAULT
Nov 24, 2007 | Altec Lansing iM3 Computer Speakers
Olympia InfoGlobe Caller ID Logo
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
