Question about Aiptek DV8800 Digital Camera
Strobe charge ? how too
How do i charge the strob
**** a ****
Posted on Feb 24, 2009
My S&W flashlight is stuck in strob mode and won't go to the other modes. I can't find a model number anywhere.nice light but need steady beam not strobe function.
See if it says anywhere on it: Made in China.
If so, only an electrical expert could fix it, and I think few would try. These are made to work until the don't, and then you are supposed to buy a new one.
Sorry.
Jan 23, 2017 | The Watches
My rca 32 inch lcd tv has a strob affects. What can I do. It every channel and it is all the time.
Do you get the same effect if you play a DVD through your set? If not, then the problem is perhaps with your aerial or your receiver if it is separate from your TV.
Jan 05, 2016 | RCA Televison & Video
Screen strobbing
you have to check for a loose contact at the main board then you can check the flyback transformer which have leak. the the high voltage is arching at the picture tube.
Feb 17, 2013 | RCA F32650 32" TV
Hotshoe and sync cable will not fire strobs. However, if I connect the sync cord via my SB800 the strobe will fire.... Help :D
What strobe are you using besides the SB800? Probably the best solution is to use a hotshoe extender for the mystery strobe (like an SC-15), and then set the SB800 in SU-4 mode (i.e. fire when any other strobe around it fires).
Sounds like the mystery strobe isn't triggering correctly with the sync signal that the body is giving through your adapter.
Mar 09, 2011 | Cameras
When i try to use flash it just says strobe charge
Before the flash can work, the strobe have to be charged. as soon as that is done it well say ready.
Feb 02, 2010 | Aiptek ISDV2.4 Flash Media Camcorder
SU-800 and SB-600 line of sight
Remember that the SU-800 works by sending out an infra red beam as the trigger pulse, when out doors available light can swamp the sensor on the side of the flash with too much light, therefore the flash cannot "see" the pulse from the SU-800.
Also if you refer to the manual, you will find nikon recommends working within approx 30 / 60  degree angle of the sensor, so if you were working behind the camera with the flash it would have had even more trouble.
As you found when you used your hand you strengthened the output beam for the flash to be able to pick up the pulsed output beam. You may need to create some kind of hood, to place in front of the SU-800 to direct the beam in the direction you need it to work.
Hope this helps  Ian
Aug 07, 2009 | Nikon Speedlight SB-600 TTL Flash
I can't get flash to work on my camera
Make sure you have good strong batteries. "Strobe Charge" is what the camera says when it's sending power to the strobes that make the flash. It can take alot of juice and if you're using weak or old batteries they may not be able to handle the load. I found with my DSLR that the Energizer Lithium batteries are great for cameras and have been using those exclusively in all my cameras. I just got the Aiptek about a month ago, have not changed batteries yet. My other digital video camera ran for over two months on one set of them, and I used it alot. It's on it's second set now and my husband has it.
Feb 10, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
Can't initialize @ start up lights strob and display reads c 1?
after you turn on, can you make copies, does the unit creates any grinding noise, please let me know.
Jan 17, 2009 | HP OfficeJet 7110 All-In-One Thermal...
STROBE WON'T CHARGE
you gotta go buy a new charger,or see if your company will replace it.The chargers for the strobe are garbage
Oct 19, 2007 | Kyocera Switchback KX21 Cellular Phone
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
Aiptek DV8800 Digital Camera Logo
124 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
