Question about HP Officejet 4500 Wireless All-in-One Inkjet Printer with Copy/Fax/Print/
Print cartridge problem black refer to device documentation to troubleshoot
hvpatel
  • 152 Answers
SOURCE: hp 4355 cartridge error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Posted on Mar 29, 2008
sethdileswar
  • 253 Answers
cartridge use same number.
Posted on Jun 30, 2008
SOURCE: Cartridge Error
I had the cartridge error message aswell. I took an alcohol swab and cleaned the points on both cartridges, let the cartridges sit for 1 minute to dry, and replace cartridges, restart printer, problem solved. Apparently I haven't used this printer in a month or so, and left it in my car and the ink dryed and caused an error.
Posted on Dec 21, 2008
SOURCE: cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
Posted on Jun 28, 2009
komguy
  • 2306 Answers
SOURCE: alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Posted on Nov 19, 2009
Testimonial: "Tried that, unfortunatley not solved my problem argh!!"
Wont print copies it said documentation trouble shooting cartridges
Hi, first if you have just fitted them, open it up again and double check that they are properly inserted..
Dec 21, 2014 | HP Officejet 4500 All-in-One -...
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
I got 3 months ago message on hp officejet j4580 display: Print cartridge problem: [Tri-Colour]. Refer to device documentation to troubleshoot. Today while printing a document, i noticed printing with...
You must be using HP60.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4580 is pretty new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
When I print, the black ink skips or sometimes doesn't print anything. I put in a new cartridge (no improvement), manually cleaned printer head, tried to manually align printer and it says alignment...
unless you are printing and choosing black only, the printer uses the color cartridge also. Go into advanced settings and choose black only. If not you may try and replace the color cartridge, or return the cartridge, it might be defective.
Jan 15, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel
Hi iam gaurav patil Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel 2 day i refil my cartridge then also i cant print my docs pls solve my problem
Aug 31, 2010 | HP Photosmart C5280 Printer
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4500 Wireless All-in-One Inkjet Printer with Copy/Fax/Print/ Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
