Question about Pengo 03101 MP3 Player
Keeps shutting my mp3 keeps shutting downwhile playing music so what can i do?
  • Anonymous Nov 11, 2007
    Pengo 1gb (blue) player shuts off @ random times.
Try a differrent brand of batteries or put new ones in or some one could have broken the very fragile usb port by hitting it while it wasd in the computer.
Posted on Oct 31, 2008
6ya staff
SOURCE:
I have downloaded music to naxa nm 100 mp3 player and now i cannot not make it play. The controls are very hard to manuver and it keeps saying the disk is empty. But when I connect it via the USB port,...
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Apr 04, 2011 | Audio Players & Recorders
How do i get music to play at the same time as showing my photos?
put songs on mp3 player so it can have songs then it can show a picture with the songs that u r listen to rite now but here the thing if u have the music playing with ur music it can shut down the music then it come up the picture
May 21, 2010 | Audio Players & Recorders
I Keep getting "playback error" "format not supported" on lgcf360
Hello All, I think I may have a solution for the 'Playback Error'problem with the LG CF360. Below, I have put the steps that caused my phone tohave the error and then the steps I took to get rid of the error. Firstly, my CF 360 worked well for hours of playing songswithout any error. Then, after I did the following steps, the error happenedover and over.
  • I pushed a mp3 ring tone via blue tooth to the phone with the SD card in. It saved the ring tone in the SD card, but I wanted it on the phone in case the card was out, it would still ring.
  • I took out the SD card and pushed the same file to the phone, so it would save on the phone and not the SD card.
  • I also pushed another mp3 to the phone.
Then, the "Playback error" happened intermittently every fewminutes. This may have been caused by either
  1. The phone's library of mp3's being corrupted because of the same file in two locations, or
  2. The phone's physical memory getting too low to effectively play music.
Here are the steps I took that got rid of the error.
  • Delete the duplicate mp3 from the SD card
  • Move all music mp3's to the SD card and off of the phone.
  • Move some pictures to the SD and off of the phone.
  • Shut off phone
  • Take out SD card.
  • Turn on phone and try to play a playlist of songs that were on the SD card (causes the phone not find the file and update the music library)
  • Put in SD card while the phone is on. (causes the phone to re-build the music library).
After I did this, I have played mp3's for hours without anyerrors at all, just like before. Either I had too much stuff on the phone orthe music library was not correct causing the crash. I hope it helps. Mike
Aug 14, 2009 | LG CF360 Cell Phone
When trying to play the music on my Ipod it keeps reading format error. Why is it doing this and how can i get the music to play? Ehen I try to sync wiht windows media, it says did not fit on device.
MP3 files come in different resolutions try to load some different MP3's (from a diff source) and see if those work, they should. BionicSam
May 20, 2009 | Apple iPod touch
It keeps saying file error
Check the format of the music you are playing and if you have music that requires the license it will load the music but not play. It will show up as a file error.
Feb 28, 2009 | Coby MP300 MP3 Player
It shut off.
Turn it on by holding in the power button - it is normal for that model to go to sleep while it is playing, as a powersaving feature - but it shouldn't stop playing the music, the screen should just go away. Usually pressing any key will wake it back up.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Music format not supported.shuffle wont turn off
I am not sure about why the shuffle will not shut off, but you can check out your user manual here.
As for the songs, just keep in mind that anything with copyright protections (like a lot of songs illegally download off the internet) will not be supported and cause this error.
Hope this helps.
Dec 03, 2008 | Philips SA3025/37 Flash MP3 Player
Mp3 player will not play,it shuts off
I keep resetting it and finally it stayed on and started to play music,go figure. thanks for the email
Nov 06, 2008 | Audio Players & Recorders
Auto shut to work
This function is kind of confusing. It will not shut the player down while music is playing. It's just basically a battery-saving function. Say you leave your player on and not playing. After set amount of minutes it'll shut off to save battery life, but not if it's playing music. Odd function, eh?
(btw, this is what i've found to be the function and may not be 100% right.)
Aug 25, 2008 | SanDisk Sansa e260 MP3 Player
Pengo 03101 MP3 Player Logo
50 people viewed this question
Top Pengo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Pengo Audio Player and Recorder Expert? Answer questions, earn points and help others
