Question about Oster 5834 ExpressBake Bread Maker
I cant get the select button to change to the WW setting it just says P1
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
KENWOOD DNX5120 DVD Navigation System GPS Receiver: I just purchased a used vehicle with this system. ...
Its a lil Play button at da bottom of screen wen on tuner! tap it until it say p1 p2 p3 etc, turn to wat station you want and hold either p1 p2 p3 etc!
May 09, 2010 | Kenwood DNX5120 DVD Navigation System GPS...
How to enter code for freelander 1998 Radio R770
Philips / R770 Rover Code Entry
Switch on the radio, the display will show 'C'
Press [P1] followed by the tuning button to rotate the first digit
Press [P1] followed by the tuning button to rotate the second digit
Press [P1] followed by the tuning button to rotate the third digit
Press [P1] followed by the tuning button to rotate the fourth digit
Finally if the correct code is shown on screen press the [P1] button to save the code.
Jan 10, 2010 | Car Audio & Video
Hi ! i cant find a driver for my model webcam
Driver is available on website other then Sony Support so download it at your own risk. Make sure Anti-Virus software is installed and updated in your computer.
Click HERE to download driver for Sony SNC-P1 camera.
Oct 22, 2009 | Sony SNC-P1 Network Camera
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
I have a problem that . i cant change sms tone except the samsung mobile tone .which is inbuild. how could change this,...
SETTINGS>>PROFILE SETTINGS>>SELECT YOUR DESIRED PROFILE>>MESSAGE SETTINGS(RIGHT POINT OF YOUR SCROLLING BUTTON>>MESSAGE ALERT TONES>>CHANGE>>USE MY ALERT TONE>> EXPLORE>>> SELECT AND SAVE>>> YOUR PROBLEM IS SOLVED!!!!!!!!
Mar 17, 2009 | Samsung SGH-L700 Cell Phone
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
I cant change a ankle strap
get some flow bindings...lol. you might want to try to use a little lubricant like wd-40 where the release button is on the ankle strap, they do tend to stick and make it difficult to remove straps.
Dec 28, 2008 | Winter Sports
Oster 5834 ExpressBake Bread Maker Logo
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
