Question about Garden
Turn off choke, engine stops
I start engine and it runs fine with choke in half position. Engine quits when moving choke to OFF position.
    Problem Solver:
  • 30 Answers
You may need to adjust the carb.
Posted on Jan 03, 2013
  • 49 Answers
SOURCE: snow blower is running sluggish with the choke in the on position
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Posted on Jan 29, 2009
mickey813
  • 472 Answers
SOURCE: adjust throttle speed
YES YOU DO BUT YOU NEED A TOOL THAT ONLEY SHOPS HAVE LET ME KNOW IF I NEED TO TELL YA WERE TO TAKE IT
Posted on Oct 12, 2009
  • 110 Answers
SOURCE: Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Posted on Oct 31, 2009
  • 85 Answers
SOURCE: Home Lite gas Engine starts but will only run at high speed at
you may need to replace the screen in the carb.
Posted on Nov 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: engine will only run with full choke on, engine
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 25, 2009
Testimonial: "Thanks Jim, the only thing I did not do was clean the small screen. Thanks again. Great advice. Gary"
Honda cg160 tiller the engine was running rough With choke all the way in, fine at halfway. then stopped moving forward,moves but no strength to till. What's wrong??
while your choke is out your engine is getting too much petrol . if it wont run well with choke in then its not getting enough. there is a small screw on the side of the carb ( air mixture ) they are usualy ( from screwed right in ) 1 and a half turns out, try with 1 and a half turns out start engine and adust either way so it idles nice ( try and warm engine up first ) also if you can't get it to idle you might have to strip card off and clean it ...hope this helps
Apr 23, 2015 | Honda Garden
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Sym red devil feels sluggish
Instructions
    • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
    • 2 Pull the kill switch up.
    • 3 Turn the key to the "on" position.
    • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
    • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
    • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
    • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
    • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
    • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
    • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
Jan 15, 2013 | Motorcycles
Instructions
Jan 15, 2013 | 2008 Sym Jet Red Devil 50
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
Cannot get the brushcutter started, it has spark but doesn't want to go. Have forgotten the method of starting, eg. 10 prime pumps, five pulls with full choke but turned off, then half choke turn on...
Normal starting practice is always done with the ignition on, primer as many times as it takes to 3/4 fill the bulb, move choke to full closed, crank engine until it fires once, move choke to half if there is a half position, crank engine until it starts and runs, move choke to full off.
Aug 24, 2011 | Garden
Engine starts fine but lacks power until it warms up for 2 to 5 minutes. Carb is ok, replaced head gasket. Just started doing this
If it starts at completely cold to fine tune the high jet adjustment.first off the high speed jet should be initially set at 1 1/2 turns out from lightly bottomed all the way in. next when you do your prestart routine,choke all the way on,primer pumped two times,throttle set at the high speed position,ignition key on,fuel line turned on.(this is my prestartup for my 8hp tecumseh)yours may be slightly different.use whatever starts your machine the easiest! once my machine starts up i can almost immediately turn the choke completely off. i can do that because the high speed jet is opened enough or rich enough for the engine to run.if you adjust the high speed in it will lean the motor out(you found that to be true!) to where it will miss and backfire and eventually quit. start at 1 1/2 turns out and start the engine,once the engine starts if you take the choke off right away use what it does as a guide to high speed adjustment. if the engine quits turn the screw out 1/4 turn and so on.use the very first cold startup as the test for high speed mixture adjustment. at completely cold startup you have the jet adjusted correctly when the engine will sustain itself when you completely take the choke off very shortly after startup. let the amount of choke you need at cold start to keep the engine running be your guide.too lean and the engine will not stay running without the choke at all,too rich and the engine will not pull under extreme loads and will show signs of black soot out the exhaust. you want the jet adjusted so within 5 seconds of cold start the engine will stay running with no choke at all. find that needle setting ( don't ad any more!! ) and you'll be good to go.keep in mind the above is not optimum and is a little rich but you will like the way it starts,stays running,and overall performs as adjusted above.
Oct 03, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Engine run @ half choke but will not run in run position
It's starving for fuel. What is it? Sounds like the jets are plugged in the carb. or possibly water in the gas. Remove carb., disassemble, clean and put back together. You should get a rebuild kit for it first so you have new gaskets, etc. when you reassemble. It's a little more complex than I can put in words for you here.
Also empty and clean fuel tank too and start with fresh, clean fuel.
Mar 11, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
