Question about Yamato Digital Pizza And Baking Scale Pb-200 Hands Free
ErrL error message
The digital scale was working properly all day. Went to use it for another customer and on the display it read "ErrL". It was on level ground with nothing making it lean or tilt. Nothing was on top of the scale, weighing it down. I tried to zero the scale out and even unplugged power source. Even after that, and powering back on, it still came on and read ErrL. The foot petal is not attached and hasn't been for almost 2 years. Any ideas on how to fix, or is it just old and ready to be replaced?
My healtho meter scale says errl and won't reset.I put new batteries in but still get the same error
Underneath the scale there should be a tiny hole marked R or RESET.
Straighten a paperclip and press it into this hole for five seconds and that should do the trick.
If not, try this again but with the batteries removed.
Replace the batteries and switch on.
Apr 13, 2015 | Healthometer Health o meter HDM691DQN 95...
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Nothing will display on the read out
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Scale goes to sleep mode and could not be activated.
REPAIRING DIGITAL DISPLAY SCALE -- SALTER BRAND WITH ERROR MESSAGE, AND EVENTUALLY NO DISPLAY AT ALL
I managed to fix a Salter digital display bathroom scale I had bought for my mom by removing dust from the area that turns it on -- the design fit perfectly with her decor so she didn`t want it replaced with a different style.
MODEL: It was model 910 but I imagine the fix will work with other similar models.
PROBLEM: The scale had been working only occasionally for many weeks and was hard to turn on -- my mom said it no longer made the little click sound when she pressed it with her foot to turn it on. Finally it gave an error display and stopped working entirely with no display at all -- not even the dashes to indicate it was getting any power from the battery.
SOLUTION: When changing the battery and cleaning out its compartment failed, I suspected that maybe dust had gotten into another area -- the part that turns it on -- on this scale they`re little silver discs under the glass that press into the base (the dust would explain the lack of the usual metallic click sound and the lack of contact to switch it on). The area is not very accessible, so I used a high power vacuum with crevice attachment in my left hand, while loosening the dust with a duster/paintbrush in my right. The trick was to find the right duster and then work both tools around each disc coming at the same point from different angles. The first time I used a small duster with man-made materials (not feathers) and tried to push it into the crevice so that at least some bristles turned the corner down into the base -- the vacuum was strong enough to pull any loose dust out. This first cleaning went well enough to get the display back on when I tried it -- back to the error message anyway, but I knew I was on the right track. The second time I used a skinny fine detail number 1 paint brush (similar to the ones in a child`s paint set) to loosen the dirt while using the vacuum -- I pushed horizontally in toward the disc, and then twirled it back and forth so that the bristles splayed and the lower half of them curved down into the crevice. This worked well and afterwards the scale turned on and went to 00 and read my weight. A third cleaning with the vacuum and paint brush even brought back the little "click" sound and my mom says that since fixing it the scale works better now than it has in a couple years.
Hope this repair works for you. All in all it took less time than it would to find contact info to call/e-mail for a return/replacement, wrap/box/label it, and take it to the post office -- not to mention saving shipping charges.
Mar 07, 2009 | Salter 9007 Glass Lithium Digital Scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Jan 28, 2009 | Conair Weight Watchers Glass Digital Body...
Yamato Digital Pizza And Baking Scale Pb-200 Hands Free Logo
78 people viewed this question
Top Yamato Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Yamato Measuring Tool and Sensor Expert? Answer questions, earn points and help others
