Question about Microsoft Office Excel 2003 for PC
I want verify the data drop town list and its formulas
  • 156 Answers
Hi Manjee,
There is no formula used in data dropdown list, so it can not be verified as a formula using evaluate formula, trace errors, trace dependents, trace precedents etc.
If you want to create such lists simply:-
  • Select input range then goto
    data --> validation --> allow, list --> select the list range
  • To veryfy you can follow the same process
    data --> validation --> allow, list ,
    now you can see the exact range from where the data is picked.
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Posted on Jan 31, 2009
Hi, My formula will not give me the correct sum when I drag it down into new columns even though the formula is correct. Please advise
What happens if you copy the formula from one cell and paste it into another? Sometimes formulas don't drag correctly. This can happen especially when you have more complex formulas. Another thing that can throw off the drag and drop copying of formulas are hidden rows or columns.
If a copy paste doesn't fix the issue than reply with the exact formula and a snippet of your data so I can troubleshoot it better.
Apr 04, 2017 | The Computers & Internet
What is formula to use 5 point drop down list to fill specific ce
In the cell where you want the data to be stored use the =cell formula
for example =CELL("contents",A2). now A2 is where your dropdown list is. put this code where you want the data to be stored.
Nov 29, 2009 | Microsoft Excel for PC
What is formula to use 5 point drop down list to prompt entry of cell value into specific location
You can use cell validation.
Select the cells you want to have the dropdown list.
Press the following keys "alt" "d" "l" and you get a message box.
select List from the drop down.
Now you can type in your list in the blank box separated by commas
Excel farmulas
Add another colum, say D with result of B*C
Do a list of the different cat, and use sumif
For cat 0101 (in cell F1)
formula to put in G1
=sumif($A$1:$A$7000;F1;$D$1:$D$7000) where F1 contain 0101
expand the formula for other cat. (G2, G3, etc)
You can use a assistant to extract the distinct cat from A1:A7000, sorting them and copy the result in F (Menu Data-> Filter -> elaborate filter)
Feb 16, 2009 | Microsoft Excel for PC
How to use vlookup
you can a tutorial here.
please rate.
Feb 06, 2009 | Microsoft Excel for PC
Excel - Find the last, 2nd last and 3rd last data in a column
There isn't enough information to make a formuls for you. I normally just go to where I want to put my formula, hit the Auto-Sum button and modify it to suite what I want. Make sure you don't have formatting set for auto or turned off for the cells you want to work with.
Dec 29, 2008 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Excel
Would you not be better off with a pivot table ?
To use multiple drop downs - each listing would need to be associated, or have a column that causes a relationship.
When selection 1 is made - a formula will dictate what fields to make visible (available) in the next menu..
you could build a macro in that will 'lift' the formulised data, and 'paste as values' it into a control area that will then give you a definitve second list based purely on the initial drop down.
Hope this makes sense
Aug 12, 2008 | Microsoft Excel for PC
Asking Excel to insert a drop down list based on previously entered text
Yes...no....yes....and yes. And if that sounds like a funny response let me explain. First of all you can write a formula for a specific cell (or cells or interrelated cells where you menus would display). It takes a while and if you are new to the syntax it could take a couple hours even (let's assume you are not a math major). Using Access, for something this apparently simple, I would not suggest (another learning curve but admittedly a reasonably easy one). But, this is the second yes, the easiest way to do this would be to simply insert a "comment". When you hold the cursor over the cell...your data...i.e. menu...will pop up. And yes...(last yes) you could have Sunday thru Monday across the top and Breakfast, lunch and dinner in the right hand column. Now this assumes what you have said is what your are trying to do...effectively meal planning...and you are not trying to plug in the inventory in the fridge to develop a shopping list.
Lastly...yes I could write the formula....but not knowing what you do (and figuring if you are going to use Excel at all you really do need to learn how to do it) I would be wasting a bit of time. Hope this helps...Tango.
Feb 04, 2008 | Microsoft Excel for PC
Formula required
at first select the 1st page data and select data-subtotal from the upper menu list.
then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
If not solved pls get me that data as to reference.
thanks
Dec 04, 2007 | Microsoft Excel for PC
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Microsoft Office Excel 2003 for PC Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
