Question about Mitsubishi SD430U DLP Projector
Projection problems My lamp has been replaced and after a few weeks my picture has a shadow effect to it and i've tried all the functions to fix it and can not seem to do so? Almost a 3D look but in a bad way.
    Champion:
  • Mitsubishi Expert
  • 225 Answers
It is a bad vga cable?
Posted on Nov 26, 2013
I replaced the lamp on 62530 worked fine for a few days, now the picture won't come on and the lamp light does come on.
unplug the unit wait 30-60 seconds & plug back in. Try unplugging your source at TV input & then plug it back in
Jan 03, 2015 | Mitsubishi Cooling Fan Set for WD-62530
Picture has progressively darkened over the past few months. Replaced the lamp which did not help. Next place suggested replacing te lamp ballast which did not help either. Now I'm being told it s
You might want to talk to JVC as this model had all kinds of issues--missing any color, picture inverted or backwards just to mention a few.
The solution was to connect it to a computer and use a jig from JVC and download two up grades on sd cards and install them manually.
I mention this as the Light engine in the set communicates with the main chassis and you in fact may have a issue with that.
At least make a call to JVC---saw about 40 sets with this model where this cures all sorts of communication issues--the engine if "set" wrong could easily cause this problem.
Dec 19, 2012 | JVC HD-52G786 52" Rear Projection HDTV
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
How do I know if I need a new lamp?
Buy original Lamp: 800 638-3328
DO NOT BUY the cheap lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
I can't get the 3 colors to be one picture - I've got shadowing (or triple picture)
Set will need both the STK-392-560 convergence chips replaced===several sites sell kits with all the parts needed by brand/model number with instructions.
May 19, 2012 | Sony KP-57WS500 57" Rear Projection...
A blue shadow on the left side of the picture. Do
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi SD430U DLP Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
