Question about Black & Decker SpaceMaker ODC150 Coffee Maker
Water does not get warn and not move to coffee side
Coffee bottle bottom plate gets warm, but water does not warm and not move to other side.
  • youngsoon kim Jan 06, 2013
    The water does not get warm, and the water does not travel from the water container to the coffee pot.
    And also, the tray underneath the coffee pot does get hot, so the electricity isn't fully disfunctioning, just the water.
Needle plate keeps opening
1. Your needle plate has a spring on the bottom. Tighten if needed.
2. While you replace the plate you have to do it at an angle. Pry the spring up on one side and move the plate into place. Do the other side of the spring and move it into place.
3. This will take a few tries but with two cups of coffee you'll get it.
Feb 24, 2015 | Sewing Machines
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
Water wont heat. Warmer has no heat but light is on
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Jul 03, 2010 | GE 106591 Coffee Maker
Water just trickles thru getting less than 1/2 cup of coffee.
If you haven't descaled it yet, per instructions in the owners manual even if the warning isn't present, try that first. If that doesn't work, get a can of compressed air, and insert the nozzle of the can into the upper nozzle of the brewer, the one that pierces the top of the cup, and give it a blast of air. This will dislodge any crud that is preventing the water from coming thru.
Mar 31, 2010 | Keurig B60 Coffee Maker
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
Cold coffee
Is it the coffee maker itself or the warming plate?
If it's the warming plate I would suggest geting a coffee thermos similar to the ones they have at IHOP and other breakfast places, it will keep your coffee hot all day if you first heat it up with very hot water and your coffee will not have the burned taste
Please answer if the answer works for you, thanks
Feb 13, 2009 | Cook's Essentials CEMB10TC
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
My coffeepot the Gevalia model above will not brew this mornign
There's a little Thermocouple that can burn out on coffee makers, it's usually mounted by the warming plate. It's about an inch long and looks like a tiny bullet. It's a safety device and should be replaced, not jumped out. Radio shack may have them.
Geno
Jan 23, 2008 | Gevalia 25280 / 50304 / 60130 / 50431...
Black & Decker TCM700 Coffee Maker problem
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Black & Decker SpaceMaker ODC150 Coffee Maker Logo
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
