Question about Singer Sewing Machines
I have an industrial singer 457. First time I am changing the bobbin and now my thread is all messed up. The thread under the fabric is all loose and bunched up. What should I do?
  • Singer Master
  • 7,365 Answers
Adjust the top thread tension one number or letter at a time on a
scrap piece of fabric till you get the correct stitch
turn the bobbin the opposite direction
here is a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Posted on Jan 03, 2013
bilabon
  • 46 Answers
SOURCE: thread bunching up under fabric.
Be sure that the thread is in the TAKE-UP lever. There are four thead guide the thread must pass through. From the spool through the first thread guide at #1 than straight down to #2 than up to #3 throught the take-up lever and straight down to the left of the needle and throught hte neele form fornt ot back.
If the thread is not in that take-up lever the machine will not have any top tension (or be regulated) it will flood the machine with thread and wrap around that bobbin.
Also, be sure have you presser foot int he up position while threading this way the thread will surely pass through the tension disks, Set your top tension at 4, use good quality thread (get rid of the dual duty or all purpose) All of these steps will ensure a perfect balanced stitch.
Posted on Nov 06, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 69 Answers
SOURCE: need online manual
If you are having problems with the thread on the underside of the fabric, that is usually the upper tension. Check to make sure that it is threaded correctly. If so, make sure that the thread is inside the tension disc and that there are no pieces of thread caught in the tension. If it is threaded and there are no thread caught up in the tension assembly, adjust your tension dial to a slightly higher number. Do this until you get a good stitch.
Posted on Feb 12, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 255 Answers
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Posted on Jan 26, 2010
Threads bunching up on singer 7256 when i start sewing
1. I believe that your bobbin tension is too tight.
2. Your top tension should be at about four.
3. When you do your top threading check the tension before threading the needle. It should have some tension but it can't be too loose. Do this with the foot down.
4. If you have adjusted the bobbin more loosely replace it and turn the hand wheel with some fabric in place. It should come out with a nice stitch. You may have to do very small adjustments to the top tension to make the stitch perfect.
Nov 04, 2016 | Singer 7256 Sewing Machine
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
What are the dial for tension to be set at.
Hello Michele, I would check to see if the machine is threaded correctly. Your problem could be in the thread take up arm and thread tensioner.
Aug 24, 2015 | Singer 2662
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
