Question about Casio TE-2400 Cash Register
My cash register locked when 1 turned the key from reg, i accidently scanned something and tried to unlock but now it is making scanning noise everytime i scan items but price is not coming up on ti
All the items are saved on a pc, but when I scan individual items no price is coming up I used the manual to unlock by pressing pgm key afterwards and a reciept came out but still not scanning
  • Casio Expert
  • 592 Answers
Rest you machine to factory settings and downlowd again the program from the computer
Posted on Mar 18, 2014
Sharp XE*A20S error code 7-15P
It sounds like you are seeing the time display. Turn the key to REG mode and try pressing CL (clear). If it doesn't beep, get the keyboard checked by a technician
May 12, 2015 | Sharp XE-A202 Cash Register
Casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
Oct 07, 2008 | Casio Parts Cash Register PC Desktop
Sharp ER A180 don't work only makes beep beep
Your key on Reg press 1 then #/cash key(Blue key on topmost right)
Apr 28, 2015 | Retail Supplies
I deleted the cash button on the er-380 how do i program it back?
Turn Key to "s" mode (one turn more clockwise from PGM "6pm")
Enter "7" "0" "subtotal"
Enter "1" "4" "1" and then press your "missing cash button"
then
press "cash button" to confirm
Return key to "REG" position
Thank You
Team
ACP ONLINE
Oct 30, 2014 | Sam4s Samsung ER-380 Cash Register
My sam4s er-180t cash register wont respond it just beeps and comes up with E00
try to do an 'initial clear'
turn power switch on right side of reg to OFF pos
turn control lock to P position
press and hold SBTL key and turn power switch to ON pos
should print 'Initial clear ok'
might need to repeat a couple of times
Jun 22, 2014 | Sam4s ER-180T Cash Register
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
How to fix e035 error on se-s2000
I tried your suggested fix Electroboy and all it did was print out some end of year totals or something that used about 5 metres of paper, I managed to get help from the Hotpos tech support guys and they gave me this sequence which immediately fixed the problem......
Turn key to program
Press
subtotal
0
0
0
0
cash
subtotal
Turn key back to reg
That's it :)
Apr 11, 2012 | Casio Parts Cash Register PC Desktop
I had posted this problem once before hopefully get assisted this time. I purchased a casio TE-4500F register with scanner I had to reinitialise it to clear old data, and reset it now the scanner red light...
Hi. This is normal. Unless you made a backup, you will have lost a lot of system programming. Firstly you must make sure you have initialised it with the code for scanning and not check tracking. To do this:
Turn key to program mode 5 SUBTOTAL SUBTOTAL
This will print the memory allocation. Next to file 16, you should see a figure in the thousands (usually 6000).
Next you need to allocate the I/O port for the scanner. Try this:
Turn key to program mode 3 SUBTOTAL 298 SUBTOTAL 2000 CASH SUBTOTAL
Now perform a flag clear to set the new I/O:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn back to REG mode and try it. You might have to log a clerk back on after the flag clear. See how you get on.
Dec 29, 2009 | Casio Parts Cash Register PC Desktop
CASIO 2400 TILL
Hi.
Try this:
Turn key to Program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Turn back to reg mode and try it.
Mark
Dec 21, 2008 | Casio Parts Cash Register PC Desktop
I cannot change the price for an item on CASIO TE-2400 register
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
Nov 16, 2008 | Casio Parts Cash Register PC Desktop
Casio TE-2400 Cash Register Logo
105 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
