Question about Bose Audio Players & Recorders
Wiring diagram for bose speakers to techwood receiver
I have a techwood reciver and i bought bose speakers how do i hook them up
techman
  • 3130 Answers
SOURCE: cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Posted on Jun 09, 2007
ward_knutson
  • 64 Answers
SOURCE: Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Posted on Nov 25, 2008
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
  • 51 Answers
SOURCE: Need a diagram to hook
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
SOURCE: Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Posted on Jan 21, 2009
Ddr94a techwood
This receiver has 100 watts per channel. If b side speakers aren't working you may have them hooked up wrong. Try connecting the B speakers to A terminals to make sure speakers are functioning. Please see the user manual below for wiring diagrams.
http://weltonusamanuals.s3.amazonaws.com/omddr94.pdf
Mar 30, 2014 | Audio Players & Recorders
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Jul 26, 2013 | Televison & Video
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
Can i hook up the bose wireless reciver for the rear speakers with a onkyo reciver
I don't see why not. Use any record out or if you can rear pre amp out connect to the input on the bose unit.
Oct 09, 2009 | Bose Acoustimass 16 Speaker
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
(Page11)
Dec 14, 2008 | Bose Acoustimass 10 II System
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Techwood 400 watt Stereo Receiver PLR85
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
Cannot hook eq to my receiver
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
41 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
