Question about Canon Pixma MP450 All-In-One InkJet Printer
Trying to add cannon mp450 printer to my mac and error 9672 shows up it will not print
  • 685 Answers
Click OK on the message prompt to close the message.
Uninstall the Epson Printer software that came with your printer using the uninstaller. Follow the on-screen prompts to uninstall the product.
From the hard drive, click Applications, then click Utilities and select the Printer Setup utility.
Click Add.
If your printer shows up in the printer list, select Printer. If the printer does not show up in the list, choose either Bonjour or Rendezvous as the connection type and then select the printer from the list.
Under the Print Using list, select epson stylus CX5000.
In the list of available drivers, select the epson stylus CX5000 - Gimp-Print driver.
Click Add
Using the Gimp-print driver might provide basic print-only functionality. This driver is a built-in driver in the Macintosh Operating System and will not provide all of the features that are provided using a direct USB connection.
Posted on May 28, 2013
  • 421 Answers
SOURCE: Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Posted on Nov 08, 2008
SOURCE: Canon PIXMA MP450
I had the same problem and spoke to canon australia technician. Any 4 number code means it is a servicable error. 6500 code specifically says take to a service centre...
bugger....but thats what they told me...
Posted on Mar 06, 2009
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Posted on Nov 11, 2009
old marine
  • 1992 Answers
SOURCE: I have a cannon MP 160 printer/scanner. It does not work on a Mac
Uninstall all your drivers (and delete the preferences) and download the Mac drivers from this link. The drivers that came with your printer were developed before Snow Leopard came out.
Posted on Jan 21, 2010
Testimonial: "thanks, this worked really well. I can now scan and print OK. Thanks Job well done."
Semi-Driver
  • 434 Answers
SOURCE: what is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Posted on Mar 27, 2010
What is error message 5100 for this printer?
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
Printer is not responding
see ther will be 2 cause of problem 1 is may be the printer driver is not proprly installed or may be check the printer cable also.
make sure when you switch on the printer it start normally without any error on display screen.
Sep 09, 2009 | Office Equipment & Supplies
Low ink lamp staying on cannon mp190
The Canon rep told you the correct information. The printer companies have included circuits on their cartridges that will not allow you to refill them. The printer reads the code and knows that the cartridge already ran out of ink. To date no one has figured out a hack for this issue.
Aug 10, 2009 | Office Equipment & Supplies
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Finding error code explanation
Solution
Uninstall the software that came with your printer . .
Click Add.
follow the on screen prompts to setup the printer
it should work
Jan 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error -9672 from Epson CX6000 Setup
Hi-
try going to Mac HD then applications then utilities folder, then go to disk utility and repair and verify your mac, then try uninstalling and reisnstalling driver. if that doesnt work, try crating a new account in which you will give an admin rights, then reinstall printer driver to that new account, then logout and return top your regular account and check if its been added.
keep me posted. thanks!
Aug 17, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
366 people viewed this question
old marine
old marine
