Question about HP (D7580-60003) Motherboard
Hey, Good evening out there, My computer can not produce anything like sound.What can i do?
    Genius:
  • 1,913 Answers
Reatttc all connection and ram .in cpu u have to open cpu cabinet.
Posted on Jan 19, 2009
I was using seagate hard disk.After some time it started producing an abnormal sound.That sound keeps on producing and my computer does'nt work.I asked an expert about this problem and he said that my...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
are the sounds beeping make sure that your RAM is securely seated
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
May 30, 2011 | Intel Motherboard
Hello, I recently installed a wireless router on my desktop home computer. Immediately upon installing the router, my Labtec desktop speakers quit producing sound. The speakers do work on another...
Hmmm.. sounds like assignments got crossed/reassigned possibly when the router was installed.
Have you looked down the list of System Hardware (control panel) to see if you have any Exclamation Marks that indicate a problem to look at?
Have you looked at the settings on the speakers in the computer? i.e. mute, equalizers, volume sliders, and even some audio software differentiates between the different connections on the back and front of your computer. Try clicking or right-clicking on the little speaker in your system tray (the icons at the end of the Start bar).. you may even have an icon in there for an audio program that you want to check out.
You can try a previous restore point, but pay special note of anything you've installed or changed since that time.
Just installing software for the router shouldn't necessitate opening up the computer, although an old tactic would be to pull the sound card out and reseat it back into the slot. Since you don't want to do that, I don't think you're missing anything unless you bumped it by accident when you were attaching the cable to the router. Since it was "immediate" I would be focused on software issues as you indicate.
You might even check out the support for the Labtec website rather than the MS route you've taken already.
Good luck!!
8^)
Jan 02, 2011 | Labtec Audio Players & Recorders
How can I download sound in my precision/m70 pc? my pc has failed to produce any sound ,even the pc begining sound.
Please download the Audio driver here. And then uninstall and reinstall the Audio driver in the Computer.
Hope this will help you. Good luck!!!
Sep 20, 2010 | Dell Precision M70 Notebook
Distorted sound.
You can try shutting off Audio Hardware Acceleration.
Start > Control Panel > Sounds and Audio Devices > Advanced (Under Speaker Settings) > Performance.
Let us know
Good Luck
Apr 14, 2009 | Audio Players & Recorders
JL audio 500/1 produces barely any sound
have you checked the input sensor on the amp?
Oct 28, 2008 | Jl Audio 500/1 Car Audio Amplifier
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Sound dificulties
Hi, it sounds like your onboard sound is faulty,
Purchase and install a PCI sound card, these are reasonable cheap and produce good sound quality.
regards mistyman
Nov 29, 2007 | Edirol UA-4FX External Sound System
No image, Hear sound, Flashing light
Look for over-heated area on PCB===change 47mf/25v cap and two xistors== BC-327-25=BC-328 BC-337-25=BC-338 This solution is offered for L04-01 chassis.
Oct 01, 2007 | Philips 27PT6442 TV
HP (D7580-60003) Motherboard Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
