Question about Dishwashers
I HAVE A KITCHEN AID DISHWASHER model number KUDM25SHBL1. AND IT WONT DRAIN ALL THE WATER OUT AT THE END OF THE CYCLE. WHTA COULD BE THE PROBLEM?
ALL THE WATER DOES NOT DRAIN OUT AT THE END OF THE CYCLE. iF I RUN THE CANCEL CYCLE AGAIN IT WILL THEN DRAIN IT. wHAT COULD BE THE PROBLEM
4 Suggested Answers
  • 11 Answers
SOURCE: Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
GodBlessU
  • 3513 Answers
SOURCE: Have a Kitchen-Aid built in
Have a look in the tub and see that the float cup is free and not hung up. If it is stuck, the water valve will not work. You can also take the lower panel off and test the water valve with a meter for continuity.
Please check the article bellow to have an in-depth knowledge related to your query:-
http://www.partselect.com/dishwasher+dishwasher-wont-fill+repair.htm
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 20, 2010
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Water wont pump out at end of cycle
it would be helpful to have the full model number of the dishwasher.
do you get any lights flashing? how do you know it is end of cycle? could be still in wash and not got to rinse at all. Do you hear the drain motor running?
Try with a shorter cycle like simple rinse only and see if it drains the water.
I am assuming you have checked the filters are clean and there is no blockage in the kitchen drain.
Jan 10, 2011 | GE Dishwashers
Water not draining in bottom of dishwasher
it might help to know the full model number of the dishwasher.
if the drain motor can be heard at the end of cycle and yet no water is draining out, then there could be a blocked drain hose or kitchen sink.
if you cannot hear the drain motor operating then it is a likely blockage or fault in the drain pump/ motor.
Jan 07, 2011 | Whirlpool Dishwashers
2-3 inches water left in bottom of dishwasher after it finishes it's cycle model DU81OCWDQ5
The model number of your dishwasher is DU810... (zero not O).
Please refer page 28 of user manual. It is normal for some water to stay at end of cycle. However, check if the air gap (if insalled) is clear. Also make sure the kitchen side of drain hose is clear.
Unless there is a fault condition shown by flashing lights, then it is pretty normal operation.
In case in future you need to refer to the parts of your dishwasher you can refer this site.
Jan 02, 2011 | Whirlpool Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
