Low audio volume control button at the highest level is to low
    Problem Solver:
  • 6 Answers
Click on ( mixer ) and see all columns , you will find one low , turn it up
Posted on Jan 03, 2013
4 Suggested Answers
  • 24 Answers
SOURCE: Volume is too low
go to sound icon in bottom right corner, click on mixer, then there is a sound output screen. I had the same problem on my laptop until i found this screen and turns out my laptop was using 20% of its volume!
Posted on Jun 15, 2009
  • 541 Answers
SOURCE: volume even at highest level can hardly
Probably the audio amp. The headphone audio is pulled off before it gets to the audio amp for the speaker.
Posted on Oct 13, 2009
  • 1768 Answers
SOURCE: Re Sony VAIO F12 (new
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Posted on Aug 10, 2010
Sniper ghost warrior 2 low sound volume
from the beginning its perfectly work but after that sounds are not coming in any stage if any 1 can pls help me to fix this
Dec 18, 2013 | City Interactive Computers & Internet
Volume too low
are you using the monitor's volume or are you using speakers? If its monitor volume, I would say go into the main menu of the monitor by pressing the menu button. Then go to the volume setting and raise the level. If the volume level is already on the highest, you may want to consider using another solution to monitor sound, such as speakers or headphones connected to your computer.
Oct 18, 2012 | ASUS Vw223t 22" Widescreen LCDFlat Panel...
My speaker volume is very low no matter what i play. All volume controls are up as high as they will go
Have you checked your system audio volume?
If you are using Windows XP go to Start menu -> Accessories -> Entertainment -> Volume Control
Make sure that the volume is set to the highest value.
Mar 04, 2011 | Polk Audio AMR50 Computer Speakers
What's wrong with my acer 4741? the sound is very low. I have adjust the sound level to the highest level. but it still doesn't work. please give me the suggestion
INSTRUCTIONAL STEPS
  • Click the "Start" button on your screen, then click on the "Control Panel." Double click on the "Sound and Audio" icon.
  • Click the "Place Volume Icon in the Taskbar" option to have it in the lower right corner. Click "OK" to save your settings.
  • Check your volume icon to make sure it does not have a red-and-white mute button around it.
  • Move the mouse click to the volume icon, then right click the mouse. Click on the "Open Volume Control" option on the pop-up menu. Remove the check on the mute button under the master control, if it is checked.
  • Move the volume slider in the master category upward. If you begin to hear sound, then the problem has been resolved.
  • Click the "Start" button on your screen, then click the "Run" option to check your Windows audio service. In the run window, type "services.msc" then click "OK."
  • Scroll down the list in the services window, then right click the "Windows audio option." Click on "Properties."
  • Select the "Automatic" option under the "Startup" tab, then click "OK." Test the sound. Try using headphones into the phone jack to test the sound
  • Click the "Start" button, then select the "control Panel" to check sound drives. Double click on "Sound and Audio" devices, then click the "Audio" tab.
  • Check the correct sound default device on your laptop under the "Sound Playback" option. If you installed other volume drivers on the laptop and you don't know the correct default, consult your user manual or contact the manufacturer.
  • Click the "OK" button ,i hope you"ll find this helpful,remember to leave your by saying how helpful this post is
  • Oct 07, 2010 | Computers & Internet
    My speakers have very low volume. I have everything set to the highest level and you can just hear them. What to do?
    test the audio amplifier with a test signal starting from the output to the preamp and SIF. check the voltage to the audio output IC , if low check the power supply.
    check the speakers .
    Sep 28, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
    Low speaker even at the highest volume level for LG 9600
    replace the speaker component, or just lift up the pin to contact to the PCB
    Feb 18, 2010 | LG VX9600 Cell Phone
    Very little volume, not very loud at highest
    On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
    Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
    Low volume
    hi, have you tried new drivers? how are the connections,cables?and check all the volume controls-look in control panel-sound devices.ect. hope this helps.i see you posted this a while ago.
    Oct 31, 2008 | Creative Labs Sound Blaster Live 5.1...
    Computers & Internet Logo
    20 people viewed this question
    David Payne
    David Payne
