Question about Waring DF280 Deep Fryer
ERR message on Waring DF280 Deep Fryer
We preheated our Waring DF280 fryer to 375, placed food in baskets and dropped into oil. When we went back a couple of minutes later to check on it, there was a message on the digital display that said "ERR." The food had stopped cooking. We pushed the reset button, unplugged the cord and the heating coil and started the process again from the beginning. We keep getting the ERR message. HELP??
5 Suggested Answers
SOURCE: Waring Pro DF200 power cord needed asap
The DF200 model has been discontinued by Waring, their parts department does not sell the power cord anymore. Unfortunately the DF250 model has a different power cord and does not work in the older model.
Posted on Jul 18, 2008
SOURCE: Waring DF200 Pro - Power Cord Needed
Hard wire this piece of junk! Problem solved w/ mine !!
Posted on Sep 07, 2008
  • 13 Answers
SOURCE: I need a manual or instruction booklet for the
Hi there, hope this is what you're looking for.
http://www.everythingkitchens.com/manuals/DF250B.pdf?r=35
Posted on Aug 28, 2009
SOURCE: My waring pro deep fryer is not heating up. How can I fix it?
There's a little black button on the bottom of the head unit which needs to be seated proproperly for it to turn on. Make sure this is in the right spot or move it around some and re-position it to see if that helps.
Posted on Sep 26, 2011
Will not heat up past 85 degrees
Take it back. There is something wrong with the thermostat or heater.
Sep 02, 2015 | Waring DF280 Deep Fryer
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
Flames coming out the exhaust
Flames coming out of the exhaust can be caused by several things.
The fryer could be set up for natural gas and it is installed on a propane system. The fryer can be leaking oil near the burner tube and the oil is burning causing excess flame. There could be grease buildup in the flue in the back of the fryer from people hanging the baskets in the wrong place.
Feb 24, 2014 | Pitco Frialator SG18S Deep Fryer
Cleaning insrtructions
Gp to a restaurant equipment store or a food broker type place, or I can ship the product to you via UPS, but there are prodcuts developed specifically for cleaning fryers out, like Mr. Muscle, Degreaser, etc. You would fill your fryer up w/water, add the solution, like a packet of Mr. Muscle, and continue to boil the mixture for some time in the fryer.... After it's boiled for some time, use a fryer brush on your heating elements, etc, which you can also buy at a local store or I can ship one to you. When the fryer is clean, you will drain the mixture out and rinse several times. You want to make sure you get all the soap residue out of the fryer or it will destroy your oil after you add it in and try to cook with it...Rinse several times, then add your oil and you should be ready to go. You can also drop your fryer baskets in the mixture just like you are cooking and the boil out product will clean them too.. Be sure to drop them again as you rinse the whole unit out.. Hope this helps. Buy a couple of green pads too, and they should help you with any outside baked on stuff
Good luck,
Susan
REO
Dec 12, 2011 | American Range AF45LP Deep Fryer
Why does the temp drop
thats easy its the law of energy and surface area you have a deep fryer that has large area of aluminum and aluminum conducts heat very well on the plus side it heats the oil quickly. on the down side it loses heat very quickly too so the machine is always turning on and off to balance the heat loss. when you place food into it that drops the temp also.
Dec 21, 2009 | Masterbuilt 20010406 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
Fryer basket
Put the one bar into the C shape and squeeze it closed with plyers, mine works great now.
Sep 03, 2007 | Rival RCF25 Deep Fryer
Food sticks to basket
try using virgin olive oil...
May 27, 2007 | Rival CZF630 Deep Fryer
Heating
Some Deep Fryers heat up faster than others, please see details below for pre-heating times: Non-Immersion Element (No element in the Oil): 25 to 30 Minutes Immersion Element (Element in the Oil): 7 to 10 Minutes Are you by any chance overloading the fryer? try smaller batches. Preheat the oven to 180 to 200 F. Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.) When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done. When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these. However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done. If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair. Good luck and bon apetite ;]
Jan 24, 2006 | Black & Decker DF200 FryMate Fryer
Waring DF280 Deep Fryer Logo
85 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
