Question about Kitchen Ranges
Can I convert a wolf AS36KI-6 from propane to gas?
Need to know if I can convert a wolf AS36KI-6 from propane to gas and if so where can I find the parts. Serial # 11005055, Year 1998
  • 1894 Answers
SOURCE: Convert natural gas range to propane
just install a new valve
Posted on Jun 09, 2008
textonor
  • 130 Answers
SOURCE: GAS RANGE
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Posted on Jun 13, 2008
jyackle5
  • 8197 Answers
SOURCE: Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Posted on Dec 17, 2008
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Posted on Mar 14, 2009
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
My wolf range model A36KI/AS36KI DON'T STOP CLIKING WHEN IS ON
Is this happening on only one burner? If so, the igniter might be dirty or the burner itself has a clogged hole(s) where the igniter is positioned. The igniter module must detect a flame, or it will keep clicking even after the burner lights. A dirty igniter or clogged burner will prevent this from happening. First, try cleaning the igniter using a q-tip and some alcohol. If that doesn't work, clean out the burner holes. IMPORTANT: Let everything dry thoroughly before attempting to light the burner after cleaning. You can use a hair dryer to help dry things out faster if you want.
Mar 05, 2014 | Wolf Manufacturing Gas Kitchen Range
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
How can you tell if a 1985 wolf range burnes gas or propane? it says propane, but we bought it saying it was for gas? And how much would it cost to change out? Thanks, Mary Kaye
Most ranges are easy to convert from propane to gas or vice versa. If there is a gas regulator installed on the back gas inlet, you could see if it is running 3-6" WC or 10-12" WC, The latter is for propane. If no regulator is present the orifice sizes will need to be checked. Propane has a higher caloric value than natural gas so the orifices are smaller. One way to see would be to install the oven. If the orifices are for propane and you are using natural gas there will be too little flame. I would estimate a conversion would cost no more than $250.00 to $300.00 depending on where you are. I would hire a professional to verify. I know it is expensive but the technician will be able to check your older oven (1985) for potentially dangerous gas leaks etc while he is there.
Jun 06, 2011 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Dec 17, 2008 | Vulcan 260L Gas Kitchen Range
GAS RANGE
Jun 13, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
