Question about Canon NP 6050 Copier
E004 probelm in 6050
Eoo4 problem for 6050 already replaced thermister still problem occurs...
along with e001 and e005 problem occurs...
  • 168 Answers
E001 thermister 004 ssr or heat lamp broke or not connected oo5 is a web out code check the connector behind the front fuser drive gear pack large connetor plugs into frame
Posted on Jan 20, 2009
How reset error code E005
You hawe to replac web on fixing unit.Than you must clear error in service mode
Aug 06, 2014 | Canon NP 6050 Copier
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
Jan 04, 2014 | Juki DDL-8700
E005 on canon
A E005 on a Canon means that the fuser cleaning web needs to be replaced and when you replace the web you also have to reset the web counter in service mode. Good Luck
Jan 22, 2011 | Canon NP 6050 Copier
System error E000202-OOO2
Is this the code you are getting? Intermittently Fuser Error Codes E001, E002, E003, E005 or E006 are occurring
Workaround :
A flat spot on the Fuser Rollers can cause Unit 1, the Fixing/Feeding Assembly, to vibrate which can effect the connection of connectors J8, J403 and J404 on Unit 1. If needed replace the Fuser Rollers, Bushings and Bearings. Then go into Service Mode Level 1> Copier > Option > Body > FX-CROT, change this setting to 3 to prevent flat spots on the fuser rollers from occurring
Mar 14, 2010 | Canon imageRUNNER C5800 Copier
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. - Cached
Sep 14, 2009 | Office Equipment & Supplies
Need a services manual with codes and fixes
E000 : The main thernistor is opened.
E001 : Thermistor in short circuit.
E002 : SSR faulty
E003 :SSR and PCB faulty
E004: SSR in short circuit.
E005: Fixing web taken up.
E010: The main motor defected.
E012:Drum motor blocated.
E013:Wastw toner feedscrew faulty.
E014:Fixing motor defect.
E020:Hooper motor failure.
E032:PCB defect.
E061:Laser unit faulty.
E100 :The DC controller PCB malfunction.
E110:Laser scanner motor defect.
E121:M4 cooling fan defect.
E196: EEPROM faulty.
E202:Scanner home positin faulty.
E204:ADF controller faulty.
E220:Lamp inverter faulty.
E225:Xenon tube malfunction.
To reset in service mode press COPIER-FUNCTION-CLEAR-ERR.
Aug 11, 2009 | Canon imageRUNNER C6800 Copier
A E004 deals with the fuser unit. Have you looked at the Thermister or the thermal fuse or the fixing lamps? I would say that most likely you have a blown or shorted thermister. One of the wires may have come off the pcb.. I you want to see the error code, I believe it is under *6* counters... *4* is for resetting the code
Jul 14, 2009 | Canon NP 6050 Copier
E005 problem in NP 6050
machine error E005 is fuser web you must replace the web
Dec 10, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
151 people viewed this question
old marine
old marine
