Question about AcerView 77E 17" CRT Monitor
Picture on my monitor is not centered
The picture on my monitor is not centered. i cannot get out of a program using the red x in the top right hand corner. is there any centering controls on the monitor? if not how do i get it centered?
  • 432 Answers
I found the user manual for your to download. http://www.theusermanualsite.com/manuals/mfg/acer/acer_acerview_77e_9990271004.html
Posted on Jun 27, 2007
When try to view program on Windows 7 computer on youtube picture is elongated and top of picture is cut off. (only when using youtube) How to solve problem?
If you're using Firefox as your browser, click on the square with the three horizontal bars in the top right corner of the browser, the menu will open, you'll see 100% in the center of the second row from the top of the drop down window. To make the screen bigger or smaller click on the minus or plus sign to either side of the 100.
Mar 18, 2015 | Microsoft Windows 7
Hi, I have a Nikon D70s. and I am using it on manual setting. the focus area is locked on the right hand side rectangle, and it does mater what I do still not working or locking on other top, bottom or...
You choose the focus area with the cursor button. It can be locked with the switch below it !!! Several settings can be monitored in the top display, 5 points for the scenery programs, chosen area for the M A S P programs. This is also a nice way to monitor what all the scenery programs do with the settings. Good luck (check the lock switch)
Oct 17, 2014 | Nikon D70s Digital Camera with 18-70mm and...
Google page not centered on monitor
You don't specify if you're PC or Mac User.
If PC user then it should be easy to fix. Top right corner of your web browser program should have three symbols: a minus sign, a box and an X.
Try clicking with your mouse on the box. It should make the program viewed slightly smaller. When it does you can move your mouse to the top of the window (usually a blue bar) and while clicking the left mouse button you can move it wherever you like (centre it).
It's more of a temporary solution and if the window is too big to fit the screen you can move the mouse to the left, right, bottom and when you move over the edge it will turn into a line with arrows at both ends.
When it does that you can click the left mouse button and drag the edge of the window to make the window smaller. Adjust each side as needed.
To fix things permanently you may have to adjust your monitor's settings using the buttons on the monitor itself. For that you're on your own as I don't know how to adjust every monitor's settings.
Jan 11, 2014 | Computers & Internet
How do i close my browser window
You can close your browser window by clicking on the red "x" in the top right hand side corner of your screen. The red "x" means "close". The "square" in the center next to the "x" means make "bigger". The - key next to the square in the upper righ hand side corner of your screen means "minimize". "Minimize" means bring the window to the bottom of the screen. It's like tucking it away or hiding it. If your window is full size and you click the minimize button, it will make the screen a smaller square in the center of your monitor. If you click it again, it hides the window at the bottom of your screen. You can see which windows re open by reading the labels at the bottom of your screen. To bring a screen back up to regular size when its minimized on the bottom - just click on it with your mouse.
Mar 03, 2011 | Mozilla Firefox
My 20 inch dell monitor is only using the left corner the screen and you can only see part of the desktop is visable and the text is upside down.
mcdevito75 here, Press the AUTO button on your monitor, if this does not work, press the MENU button, there you should see a square box with 4 arrows, these are used to center your picture on your monitor, use the left / right arrows also on your monitor to adust the screen picture with this box woth the 4 arrows from Menu.
Jul 16, 2010 | Dell ST2010 20" Monitor
Red and Blue seperate and picture curved toward the middle
You have a hardware problem, you cannot fix it using the menu. in fact you could make it worse.
Try googling DIY convergence repair if you can solder.
If not then call in a pro, about $300
Jul 12, 2009 | Toshiba 50H81 50" Rear Projection...
Red words under the words
ptc or decosing coil is bed or notworking proper so u have replace it
Jan 10, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Red deflection is way off, picture scrunched into top right corner
call 800-648-6657 order part number CZ01341. This is the convergence output ic. You will need to replace the red convergence output ic IK04.
Dec 27, 2007 | Hitachi 60SDX88B 60" Rear Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
AcerView 77E 17" CRT Monitor Logo
498 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
