I've LG wm3431hs washer dryer combo.When machine is in drying mode after few minutes in the process when drain pump is working cold water valve opens and water enters into the machine.What would be the the problem?
SOURCE: tromm won,t drain
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if
this reboots the system like when a computer acts up, we do the same
thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see
what they tell you for this specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
SOURCE: WM3988HWA Pumps Cold Water in Drying Mode!
Replace the 5 way valve. get the old flow restrictor out of the drying cold water line before reconnecting. It came out of the valve to cause the problem.
SOURCE: I have an LG Washer and Dryer Combo #WM3431HS. It
this dryer don't used external vent , please read manual, this is a vapor dryer
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
Happy drying!
SOURCE: water will not enter the machine on the cold water
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
