Question about Kitchen Ranges
Any way of repairing chip in cooktop
A bowl was dropped on the very edge of the cooktop and caused a chip. it is on the bottom left corner and not significantly close to any burner. if you look at a picture of the cooktop (model ETT304BT) it is literally on the very edge of the bottom left corner. I refuse to pay 700 or 1000 or any of these outlandish quotes to fix a chip. Ive read some reviews that say the cooktop will explode, etc, but i somewhat find that hard to believe. Is there any substitute I can use to even cover the chip??
  • 1 more comment
  • ktvango
    ktvango Jan 03, 2013
    Robert, it is a dacor cooktop model ETT304BT.. I just want to fill in the chip or something versus spend up to a grand replacing the whole thing. i dont see how leaving the chip or filling it in will cause that much problem
  • ktvango
    I'm sorry, I meant Ronald
  • ktvango
    from my reseach I'm pretty sure it is a ceramic glass cooktop
    Top Expert:
  • Kitchen Ranges Master
  • 26,232 Answers
Either leave it as it is or replace the hob as a spare part is available for most ceramic hobs.
Dacor ETT304 Cooktop Parts
I have no idea which country you are in so this site will start you off looking for spares.
Posted on May 22, 2017
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
aborcass
  • 2651 Answers
SOURCE: Cooktop not responding . . .
whats the model num???will help looking up a wire diagram or manual. look closely at all the control buttons for one thats marked with a little pic of a lock. press and hold it for 3-5 secs . . if controls locked there should be a lock lit in the display
Posted on Mar 07, 2008
  • 145 Answers
SOURCE: My Amana ceramic cooktop has
Check your warranty first. Some burners on smooth tops had long warrantys. If not first turn the power off to the unit at the breaker. If this is a in counter cooktop it has to come out of the counter and take all the screws out that hold down the top. Best to unwire from house and move whole unit to big surface to work on.
Posted on Apr 18, 2008
  • 1073 Answers
SOURCE: I have a smooth top
just the angle of the hit, not the weight of the item, granted a very light wieght item is less likely to cause damage but a large spoon hitting at the proper angle can cause this i know i was the one that did it
time for the touchup paint
Posted on Apr 21, 2008
  • 217 Answers
SOURCE: Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on Jul 11, 2008
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
Cant find model no.
You can generally found the model number for a cooktop in a few places. Sometimes the model number is faded or rubbed out. The first place I would check is directly on the bottom of the cooktop that is usually were you will find the model and serial number. Secondly, check on the units electrical box many times the label is to the right or left hand side. Lastly, some cooktops let you lift up the top to clean underneath and you can find the label somewhere around the edges.
Hope that was helpful.
Happy Holidays!
Dec 20, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
My glass cooktop has a chip on the top edge. Is there something I could fill in the chip with?
most hardware stores and some parts stores sell a special bake lite enamel paint the repair chips and cracks with on appliances
Jan 20, 2010 | Kitchen Ranges
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Crack on the corner - we have a run on the ceramic
Glass on cooktops are not fixable - due to the chance of electrical shocks the manufacturer strongly suggest replacement of the glass.
Jun 03, 2009 | Cooktops
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Can't turn burners on
I just turned the circuit breaker off then on. It must have reset the switches.
Feb 12, 2008 | Dacor Millennia CERB365 Electric Cooktop
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
