My wm51205 beko washing machine is not draining water
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Posted on May 10, 2009
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
  • 12 Answers
SOURCE: My Beko washing machine switches
sounds like circuit board is faulty
Posted on Jan 20, 2011
  • 6277 Answers
SOURCE: Hi, I have a Beko wm6123w
There is a separate motor for all of the draining parts of the cycles.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 25, 2011
Testimonial: "Thank you John...wasn't expecting anybody to come back to me or as quickly! I will try now."
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
My beko wahine machine wont drain
This Beko washing machine video will help you
Buy Paul Beer
Feb 10, 2014 | Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Nov 04, 2012 | Beko WME7247W Washing Machine
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Mar 10, 2012 | Beko Washing Machines
Beko washing machine wont drain or spin water stays in drum
Jul 01, 2009 | Washing Machines
Have a beko washing machine and the water will not drain! Any ideas PLEASE
hi there......the water is not draining because..(a) blocked filter or drain pump....(b)...failed drain pump...(c)...bocked outlet to sink...or blocked drain hose from machine
regards Sir Galahad
Jan 29, 2009 | Beko 24 in. D3421F Free-standing...
Beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Mar 31, 2008 | Washing Machines
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
