I need a owners manual for a Sharp RT-10 cassette player. The record function does not work,
The record function does not work. The tape does not turn in record mode. All other fuctions work fine.
Benimur
  • 6966 Answers
SOURCE: VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
SOURCE: Phonograph vs Cassette Player
Is your needle tight.  It has to be tight for it to work
Posted on Oct 21, 2007
philipp
  • 217 Answers
SOURCE: cassette area
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it. Check your tapes carefully, most cause of this trouble are due to defective tapes, especially sony brand, I recommend you use TDK tapes.
never force open any unit, it will only make things worst!!! [;0)
Posted on Nov 06, 2007
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
doubledip
  • 9 Answers
SOURCE: Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Posted on Apr 11, 2008
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
Find owners manual for Tascam Portastudio 414 4-Track Cassette Tape Recorder
Good morning, afternoon, evening or night; whatever time of day you're reading this solution post. Thank you for choosing FixYa to assist you with this problem. You are asking for an owner's manual for the Tascam Portastudio 414 4-Track Cassette Tape Recorder? Here is the website to download your user's manual- http://tascam.com/content/downloads/products/317/Porta_414mkII_manual.pdf
I hope this is what you're looking for and thank you for choosing FixYa to assist you with your request. Come back and visit our website again whenever you need assistance. Thank you and have a good morning, afternoon evening or night; whatever time of day you are viewing this solution post.
Apr 30, 2011 | Audio Players & Recorders
My neighbor is having trouble setting his VCR to record when he is not home. He said the VCR comes on, but does not record. He does not have the original remote control. Is there some place I can...
I hope you are not making the simple mistake of trying to record on a cassette which has a broken write protect tab. If you are, tape it up with some cellophane tape. Or try a new cassette.
Is the instant record function working otherwise ?. If so forget about the record protect tab.
Apr 29, 2011 | RCA VR692HF VHS VCR
How do you record onto a tape from a CD?
I couldn't find the exact manual but the XL-HP505 may be close enough...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Apr 27, 2011 | Sharp XL-HP500 CD Shelf System
How can I et an owners manual for my sharp stereo cassette player RT 100
hi, it may be worth writing to sharp as they will most likely have archives and im sure a nicly worded letter would net you a result
also i found this site that may have some relevant info
http://www.vintagecassette.com/Sharp/RT-10
Mar 06, 2011 | Computers & Internet
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How to erase data from the cassette tape
You are able to erase tapes on this machine by holding down the play and rewind buttons together. To clear the entire cassette, you'll need to physically turn the tape over and repeat.
Hope that helps
:o)
Nov 28, 2008 | Philips Desktop 710-T Desktop Cassette...
Record btton cannot be pressed to record
on the side opposite the tape in each corner is a plastic tab. breaking out this tab disables the record function - it is called the "record lock" use a cassette with the tabs in place.
Dec 31, 2007 | Audio Players & Recorders
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
