Question about Kenmore Refrigerators
Model106,74252400 refrigerator is 50degreese freezer cold but no ice
Refrigerator is now turned to coldest setting. it is still only 50 degrees. freezer is at coldest setting and has reached minus 10 degrees ice maker has made only 5 cubes all night and is set on maximum What can i do myself to try and fix problem?
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
dididsaythat
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
  • 139 Answers
SOURCE: Candy CPC 290 FF
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Posted on Jan 11, 2008
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Posted on Jan 26, 2010
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Our refidgerater is not cold enough running at about 50 degrees
hows the freezer?? is only the refrig warm and freezer still frezzing?? if so id open the freezer door and listen for a fan motor, it should be spinning to circulate air to the top sect(refrig). if not on sounds like a bad fan.. if the fan is on but the rear panle is completly iced over, sounds like a defrost issue
Nov 16, 2008 | Amana ABB2223DES Stainless Steel Bottom...
Freezer works fine but no cold air in refrigerator...
Dec 01, 2007 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
