Question about Maytag PYG2300A Gas Dryer
Drive belt needs replacing on Hotpoint TC71P
I have taken the side panels off and removed the broken belt.
I notice that there are two tension wheels and the belt needs to feed between them. The wheels are riveted so I can't just remove a wheel and replce once the belt has been fed throgh the middle.
I understand that I need to remove the front panel and remove the drum, but how do I get the new belt fed through the two tension wheels?
How do i get my tension correct on a hotpoint tc71p
Posted on Feb 18, 2013
Hi i can help you.. you dont remove the front panel...
email at stevenmarti n99@gmail.com and ill help you
Posted on Feb 07, 2010
My hotpoint tc71p is buzzing and not working ?
If the belt is not broken it is the capacitor on the motor that has gone it is more than likely built into the motor .Which will need changing.
Oct 05, 2014 | Hotpoint Dryers
Replacing the drive belt on a hotpoint tdc30p and need a diagram of how the belt goes round the drive and pulley system
wrap the belt around the drum first then the slack at the bottom wraps around the motor shaft. Then it has to go either left or right side of the tensioner wheel, but the flat side must touch the tensioner wheel(not the ribbed side of the belt). You know you got it right when when there is tension on the belt when it is correctly installed. I dont have diagram so this is the most simplistic way of describing how to install it.
Feb 26, 2014 | Dryers
Getting tension on a tension pulley hotpoint tc71p
hi not sure on your model i think its a fixed one with two bolts if slack i would thing wheel has collapsed will need new one about 10 pound easyest way i find to fit is taking drum out
Feb 18, 2013 | Hotpoint Dryers
Replace belt diagram
If the model number you listed this question under is correct, changing the drive belt involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt has broken, this may sometimes cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also include helpful exploded view diagrams that can help you locate and properly identify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section.
NOTE: If you still have the Teflon glide type tensioner (does not have a wheel), Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assistant may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run.
Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Kenmore 64742 Electric Dryer
How do you install the belt to the belt tension wheel?
If the model number you listed this question under is correct, changing the drive belt involves the following steps (skip down to step 6 for instructions on how to route the belt on the belt tensioner and motor pulley):
6. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
7. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
8. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
repairclinic.com
NOTE: If you still have the Teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The Teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Aug 27, 2010 | Kenmore 74602 Gas Dryer
The tumbler does not work
Most commonly this is caused by a broken or worn dryer belt. If the model number is correct, the following steps explain how to replace the belt:
If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 33 and the tensioner is listed as item 32.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
Aug 12, 2010 | Whirlpool LER4634J Electric Dryer
Model LE5705XPW1 replacing broken belt and have no idea of proper pulley position--any clues?
Replacing a dryer belt on the model dryer you have listed involves the following steps:
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 56 and the tensioner is listed as item 53.
Aug 12, 2010 | Whirlpool Dryers
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
TS 12 Reversible electric dryer
easy !! remove the front door section complete ..
remove timerknob. + screw unclip the whole panel plastic.
remove 4 screws just under the plastic panel and then 4 screws on the bottom or front pannel. leave the screws at either side ON. you can then change belt/motor/pulleys. hope this helps.
Andy...
Sep 05, 2007 | Hotpoint TS13 Electric Portable Dryer
Maytag PYG2300A Gas Dryer Logo
206 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
