I am getting a system error C6100 on a Kyocera CS-C3225. I have tried power cycle, turned it off took out all the toners, and replaced the waste *cup* turned it on with out the toner still same error.
Defective fuser heater. Defective fuser thermostat. Defective PWB. Call service person.
Posted on Jan 19, 2009
  • kafbond Jan 19, 2009
    In some cases you can reset the C 6100 - when is a false error try this:
    1. Press 10871087
    2. Press 163 then GREEN BUTTON
    3. Pick EXECUTE and press GREEN BUTOON - reset fuser
    4. turn the copier OFF, wait 20 seconds and power up the machine.
    If C 6100 goes away it was a false error if NO ...try again and if the
    C6100 persist call service
How do i reset code error c6100
Hello there, what I THINK you are asking is to reset the toner count error on the c6100 machine when you have replaced the Toner supply ?
Try this from "Ehow"
    • Turn on the power to your printer. Press the "+" key to launch the system menu.
    • 2 Press "+" to navigate the main menu until "Maintenance Menu" appears. Press "Enter" repeatedly until the display shows "Menu Reset."
    • 3 Press "Enter" to launch the system reset. The toner count will reset and the printer will return to "Online" when complete.
Sep 10, 2014 | Kyocera Office Equipment & Supplies
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
KYOCERA 1016MFPo ERROR call 7980
Contents: Waste toner reservoir overflow
copies is less than 100 thousand
sheets)
5 g.
Causes: Defective waste
toner sensor or
engine PWB.
Check procedures/corrective measures: Shake the process unit from side to side
the process unit.
toner sensor or the engine PWB.
Nov 23, 2010 | Kyocera FS-1118MFP Laser Printer
Sayiing waste toner near full
Turn the machine Off the machine and try to shake it little bit. if its not cleared you have to replace the processing unit.
It happens with me serveral times and always solved by replacing the processing unit.
Good luck
The Experts
Aug 16, 2010 | Kyocera Copystar CS-1820 Black and White...
Error E31
The waste toner box is full. Replace it with a new waste toner box.
Aug 14, 2009 | Kyocera Copystar CS-1620 Black and White...
What is code c7980 waste toner is full???
C7980, Defective waste toner sensor or engine board. Try this, shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be soved, replace the process unit. After replacing the proces sunit, turn the power switch off then on. If the problem cannot be solved, replace the waste toner sensor or the engine board.
Aug 03, 2009 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Where is waste toner on kyocera 1820
TO empty the waste toner on a KM/CS 1820 you have to remove one of the side covers from the drum unit on the machine and vac out the old toner i've had customers try to reuse the toner please do not do this. just vac it out good and your normaly good to go!!
Apr 08, 2009 | Kyocera Copystar CS-1820 Black and White...
Waste toner on Kyocera 1820
open the front cover, pull out the process unit... then unscrew the left side of the waste disposal tank (the opposite end of the toner cartridge)
Oct 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
292 people viewed this question
k24674
jasbo
jasbo
